Audax AP170M0 6-1/2" Shielded Paper Cone Polymer
Brand:|Part # 296-192
The Polymer chassis combines strength, excellent damping qualities and environmental stability (humidity, temperature and shock). It also contains a built in cosmetic ring designed for front, rear and recessed mounting.
Part # 296-192
The Polymer chassis combines strength, excellent damping qualities and environmental stability (humidity, temperature and shock). It also contains a built in cosmetic ring designed for front, rear and recessed mounting. Each unit features high loss rubber surround, high temperature voice coil and a proprietary paper cone. Specifications:* Power handling: 45 watts RMS/60 watts max * Voice coil diameter: 1" * Voice coil inductance: .57 mH * Nominal impedance: 8 ohms * DC resistance: 6.2 ohms * Frequency range: 60-8,000 Hz * Magnet weight: 8 oz. * Fs: 59.7 Hz * SPL: 87.3 dB 2.83V/1m * Vas: .63 cu. ft. * Qms: 3.3 * Qes: 1.06 * Qts: .80 * Xmax: 3.5mm * Net weight: 1.99 lbs. * Dimensions: Overall Diameter: 6-13/16", Cutout Diameter: 5-11/16", Mounting Depth: 2-15/16", Magnet Diameter: 3-1/4".
  • BrandAudax
  • Part Number296-192
  • UPC844632062490
  • Product CategoryWoofers
    (3 Reviews)
  • Weight1.99 lbs.
View similar products to the Audax AP170M0 6-1/2" Shielded Paper Cone Polymer
