Atlas Sound WMA16-23 23.5" Deep Wall Cabinet 16RU
Brand:|Model: WMA16-23|Part # 242-9430
Designed with extensive field research and contractor input, the WMA series is the perfect solution for any installation where a wall mount cabinet is required. Specifications: • Height: 33-3/4" (85.73 cm) • Width: 21-7/8" (55.56 cm) • Depth: 23-1/2" (59.84 cm).
ORDER TODAY
Ships in 7-10 Business Days
List Price$756.99
You Save20%
ShippingTRUCK ONLY
$605.99
Part # 242-9430
  • 12.5" x 12.5" cut-out on back pan allows easy cable access through mounting surface
  • Back pan includes raised mounting embosses to mount power and other accessories
  • Back pan now boxed separately on the same pallet with center section
  • Alignment Frame provides support throughout the complete center section
  • Extensive internal bracing also provides cable management/pass through
  • Finished in durable black electrostatic powder coat
  • Mirror image back pan allows left or right hinging of center section regardless of orientation
The new Atlas Sound WMA (wall mount assembly) series of wall racks provide outstanding versatility, strength and functionality all in an elegantly designed package. Constructed from 16-gauge CRS. Designed with extensive field research and contractor input, the WMA series is the perfect solution for any installation where a wall mount cabinet is required. Optional front door available (sold separately). Ships with one set of plated rack rails and (100) 10/32 x .75" rack screws with captive washers.
Specifications: • Height: 33-3/4" (85.73 cm) • Width: 21-7/8" (55.56 cm) • Depth: 23-1/2" (59.84 cm) • Shipping weight: 121.00 lbs. (54.88 kg) • Center section depth: 18" • Rack spaces: 16 • UL listed/standard: 1678.
  • Rack Spaces16U
  • BrandAtlas Sound
  • ModelWMA16-23
  • Part Number242-9430
  • UPC612079181568
  • Product CategoryRack Cabinets
  • Weight121 lbs.
View similar products to the Atlas Sound WMA16-23 23.5" Deep Wall Cabinet 16RU
in the Rack Cabinets product category.
