Atlas Sound VTF-152UCN Flush Mount Emergency Loudspeaker
Brand:|Model: VTF-152UCN|Part # 242-9425
Die-cast, water-sealed construction withstands vandalism, vermin, moisture, corrosion, and vibration during indoor or outdoor use. Terminates via barrier strips. VTF Series are flush-mount units for recessed installation.
ORDER TODAY
Ships in 7-10 Business Days
List Price$137.99
You Save20%
$109.99
Part # 242-9425
  • 25 V
  • Communications, Intercom, Electronic Alarm, and Monitoring Systems
  • High Efficiency Compression Driver for Optimum Audio Intelligibility
  • Metal Die-Cast Construction with Integral Exponential Horn
  • Operates Within a Temperature Range of -30° F to 150° F
  • Patented Voice/Tone Loudspeaker for Custom Application in High Efficiency Industrial
  • Water/Moisture, Corrosion, Dust, Vibration, and Vermin-Resistant
Through proven performance, patented VTF Series have earned worldwide acclaim for service reliability. These cost-effective units offer compact size, functional flexibility, optimum intelligibility, effective sound distribution, and high-level output. All models contain a high efficiency compression driver with maximum acoustic conversion efficiency. (A quality which reduces number of units needed to attain specified sound pressure levels and provides substantial savings in amplification-power requirements and labor costs). Die-cast, water-sealed construction withstands vandalism, vermin, moisture, corrosion, and vibration during indoor or outdoor use. Terminates via barrier strips. VTF Series are flush-mount units for recessed installation. VTF Series mount 4" or 4-11/16" SQ backboxes and require model AR or MR adapter rings respectively (order separately) Optional mounting accessories are offered including: indoor and outdoor enclosures, a bi-directional housing, adapter plates and rings.
Specifications: • Height: 6" (15.24 cm) • Width: 6" (15.24 cm) • Depth: 30-3/16" (8.10 cm) • Shipping weight: 3.60 lbs. (1.63 kg) • Frequency response: 600 Hz - 5,500 Hz (± 5 dB) • Power taps: 15, 8, 4, 2 • Dispersion: > 190° (- 6 dB pt., 1 and 2 kHz octave bands) • Sensitivity: 96.9 dB (1W/1M) • Transformer: 25 V • UL listed/standard: 1480.
  • Input Rating25V
  • Special FeaturesIndoor / Outdoor,UL1480,Water Resistant
  • ConfigurationFull-range
  • ColorNeutral Gray
  • BrandAtlas Sound
  • ModelVTF-152UCN
  • Part Number242-9425
  • UPC612079157228
  • Weight3.6 lbs.
View similar products to the Atlas Sound VTF-152UCN Flush Mount Emergency Loudspeaker
