Atlas Sound VT-157UCN Surface Mount Emergency Loudspeaker
Brand:|Model: VT-157UCN|Part # 242-9424
Die-cast, water-sealed construction withstands vandalism, vermin, moisture, corrosion, and vibration during indoor or outdoor use. Terminates via barrier strips. VT Series models are surface-mount units.
ORDER TODAY
Ships in 7-10 Business Days
List Price$133.99
You Save19%
$107.99
Part # 242-9424
  • All Models Produce High Level Output, Optimum Intelligibility, and Effective Dispersion
  • Die-Cast, Water-Sealed Housings Withstand Vandalism, Vermin, Moisture, Corrosion, & Vibration
  • Easy and Low Cost Installation Via Standard E.O. Boxes
  • Ideal for Reliable Voice/Tone Signaling in Public Area Emergency Communications
  • Model Produces High Level Output, Optimum Intelligibility, and Effective Dispersion
  • Surface Models in Neutral Gray Finish
Through proven performance, patented VT Series have earned worldwide acclaim for service reliability. These cost-effective units offer compact size, functional flexibility, optimum intelligibility, effective sound distribution, and high-level output. Model contains a high efficiency compression driver with maximum acoustic conversion efficiency. (A quality which reduces number of units needed to attain specified sound pressure levels and provides substantial savings in amplification-power requirements and labor costs.) Die-cast, water-sealed construction withstands vandalism, vermin, moisture, corrosion, and vibration during indoor or outdoor use. Terminates via barrier strips. VT Series models are surface-mount units. VT Series mounts standard 4" E.O. Boxes. Optional mounting accessories are offered including: indoor and outdoor enclosures, a bi-directional housing, adapter plates and rings. Units Meet or Exceed UL Standard 1480 for Fire Protective Signaling Systems when Used with Compatible Control Equipment.
Specifications: • Height: 4-1/4" (10.80 cm) • Width: 4-1/4" (10.80 cm) • Depth: 3-1/8" (7.94 cm) • Shipping weight: 3.50 lbs. (1.59 kg) • Frequency response: 600 Hz - 5500 Hz (± 5 dB) • Power taps: 15, 8, 4, 2 • Dispersion: > 190° (- 6 dB pt., 1 and 2 kHz octave bands) • Sensitivity: 96.9 dB (1 watt, 1 meter) • Transformer: 70.7 V • UL listed/standard: 1480.
  • Input Rating70V
  • Special FeaturesIndoor / Outdoor,UL1480,Water Resistant
  • ConfigurationFull-range
  • ColorNeutral Gray
  • BrandAtlas Sound
  • ModelVT-157UCN
  • Part Number242-9424
  • UPC612079157167
  • Weight3.5 lbs.
View similar products to the Atlas Sound VT-157UCN Surface Mount Emergency Loudspeaker
