Atlas Sound VT-152UCN Surface Mount Emergency Loudspeaker
Brand:| Model: VT-152UCN
Inside every VT loudspeaker is a small compression driver capable of high sound pressure levels, and the die-cast, water-sealed construction withstands vandalism, vermin, moisture, corrosion, and vibration during indoor or outdoor use.
  • Die-Cast, Water-Sealed Housings Withstand Vandalism, Vermin, Moisture, Corrosion, & Vibration
  • Ideal for Reliable Voice/Tone Signaling in Public Area Emergency Communications
  • Patented Emergency Loudspeakers Available in 25V or 70V versions
  • Surface Model in Neutral Gray Finish
  • VT Series Loudspeakers Produce High Level Output, Optimum Intelligibility, and Wide Dispersion
242-9423
Weight: 3.6 lbs.
ORDER TODAY
Ships in 7-10 Business Days
List Price$127.95
You Save19%
$103.50
Part # 242-9423
Through proven performance, patented VT Series fire protective signaling loudspeakers have earned worldwide acclaim for service reliability. Inside every VT loudspeaker is a small compression driver capable of high sound pressure levels, and the die-cast, water-sealed construction withstands vandalism, vermin, moisture, corrosion, and vibration during indoor or outdoor use. An internal DC blocking capacitor enables the VT to work on supervised speaker lines, and speaker wiring terminates on a barrier strip. Optional mounting accessories are offered including: indoor and outdoor enclosures, a bi-directional housing, adapter plates and rings. Neutral gray finish. Unit meets UL standard 1480 for fire protective signaling systems when used w/compatible control equipment.
Specifications: • Height: 4-1/4" (10.80 cm) • Width: 4-1/4" (10.80 cm) • Depth: 3-1/8" (7.94 cm) • Shipping weight: 3.60 lbs. (1.63 kg) • Frequency response: 600 Hz - 5500 Hz (± 5 dB) • Power taps: 15, 8, 4, 2 • Dispersion: > 190° (- 6 dB pt., 1 and 2 kHz octave bands) • Sensitivity: 96.9 dB (1W/1M) • Transformer: 25 V • UL listed/standard: 1480.
  • Input Rating25V
  • Special FeaturesIndoor / Outdoor,UL1480,Water Resistant
  • ConfigurationFull-range
  • ColorNeutral Gray
  • BrandAtlas Sound
  • ModelVT-152UCN
  • Part Number242-9423
  • UPC612079157150
  • Weight3.6 lbs.
View similar products to the Atlas Sound VT-152UCN Surface Mount Emergency Loudspeaker
Customer projects that include: Atlas Sound VT-152UCN Surface Mount Emergency Loudspeaker
