Atlas Sound SM8SUB70-B 8" Surface Mount Subwoofer
Brand:|Model: SM8SUB70-B|Part # 242-9409
The SM8SUB70 8" subwoofer system is perfect for restaurants, bars, and high-fashion retail outlets.
ORDER TODAY
Ships in 7-10 Business Days
List Price$423.99
You Save20%
$338.99
Part # 242-9409
  • Attractive, yet heavy-duty grille assembly
  • Barrier strip input for 70.7/100V/8 ohm or parallel 4 pole Speak-OnT input for 8 Ohm operation only
  • Durable black, rough-coat finish
  • Fuse protection for driver
  • Includes internal high efficiency 60 watt 70.7/100V transformer
  • Multiple 1/4"-20 inserts, providing fly points for a variety of mounting configurations
  • OmnimountT compatible
The SM8SUB70 8" subwoofer system is perfect for restaurants, bars, and high-fashion retail outlets. The system utilizes a 8" woofer housed in a 915 cubic inch multi-angle, flyable, wood enclosure system to provide extended low frequency response with a wide variety of mounting options. (Not for outdoor use!). Inserts are included for use with 1/4"-20 drop forge eyebolts, optional SM8CBKT-B /-W mounting bracket and OmniMount™ 30 series hardware. An 18 dB/octave three-pole passive crossover eliminates the need for a separate electronic network or dedicated amplification to power the speaker. Its low crossover point (120 Hz) nearly eliminates localization, allowing a designer to boundary-load the SM8SUB70-B near a wall or into a corner for maximum output, while maintaining even coverage throughout the space. A premium 70.7V transformer allows the SM8SUB70 to be paralleled with any 70.7V commercial audio system to provide extended low frequency response and more overall audio impact for foreground music systems. (Unit is also 8 ohm compatible).
Specifications: • Height: 15-1/2" (39.37 cm) • Width: 10-5/8" (26.99 cm) • Depth: 10-3/8" (26.35 cm) • Shipping weight: 26.00 lbs. (11.79 kg) • Frequency response: 55 Hz to 100 Hz • Power taps: 7.5, 15, 30, 60 • Speaker type: Sub • Dispersion: Omni • Sensitivity: 89 dB.
  • Input Rating8 ohm,70V,100V
  • Woofer Diameter8"
  • ConfigurationSubwoofer
  • ColorBlack
  • BrandAtlas Sound
  • ModelSM8SUB70-B
  • Part Number242-9409
  • UPC612079180769
  • Weight26 lbs.
View similar products to the Atlas Sound SM8SUB70-B 8" Surface Mount Subwoofer
