Atlas Sound SM12CXT-W 12" Coaxial Speaker System White
Brand:|Model: SM12CXT-W|Part # 242-9413
The SM12CXT-W features the 12CXT60—a 250 watt loudspeaker that combines a 12" diameter, low frequency transducer and a 1" exit, compression driver.
ORDER TODAY
Ships in 7-10 Business Days
List Price$700.99
You Save20%
$560.99
Part # 242-9413
  • Attractive, heavy-duty grille assembly
  • Barrier strip input for 70.7/100V/8 ohm or parallel 4 pole Speak-on input for 8 ohm operation only
  • Durable white, rough-coat finish
  • Fuse protection for low and high frequency drivers
  • High performance Compression Driver Coaxial Loudspeakers in versatile, flyable, wood enclosure
  • Includes internal, 60 watt 70.7/100V transformer (may be bypassed for 8 ohm operatiion)
  • Multiple (12) 1/4"-20 inserts, providing fly points for a variety of mounting configurations
SM Series loudspeakers offer quality sound reproduction and contemporary styling. The SM12CXT-W features the 12CXT60-a 250 watt loudspeaker that combines a 12" diameter, low frequency transducer and a 1" exit, compression driver. The speaker has a curvilinear, treated-paper cone for lower harmonic distortion, and a built-in crossover network for proper frequency transition between the two reproducers. The low frequency transducer and the high frequency driver feature permanently aligned voice coils for low distortion performance. The copper coils have Polyimide voice coil formers. The SM12CXT-W features a wood enclosure with a metal grille. Internal hardware, for flying, includes multiple (12) 1/4"-20 inserts for overheard suspension in most any orientation. Unique input panel allows use of standard 4" square box cover (Raco 753 or eq.) for applications where flex conduit is required for termination A 90 degree conical pattern (2 kHz octave band) and amazing efficiency make the SM12CXT-W a perfect choice for a wide variety of applications including school auditoriums, gymnasiums, cafeterias, church sanctuary systems, and more.
Specifications: • Height: 19" (48.26 cm) • Width: 14 1/2" (36.83 cm) • Depth: 140 1/16" (35.71875 cm) • Shipping weight: 52.00 lbs. (23.59 kg) • Frequency response: 55 Hz to 15 kHz • Power taps: 7.5, 15, 30, 60 • Speaker type: High performance coaxial • Dispersion: 90° • Sensitivity: 99 dB.
  • Input Rating8 ohm,70V,100V
  • Woofer Diameter12"
  • ConfigurationCoaxial
  • ColorWhite
  • BrandAtlas Sound
  • ModelSM12CXT-W
  • Part Number242-9413
  • UPC612079182336
  • Weight53 lbs.
View similar products to the Atlas Sound SM12CXT-W 12" Coaxial Speaker System White
