Atlas Sound SD72WV 8" Ceiling Speaker with Volume Control
Brand:|Model: SD72WV|Part # 242-9406
The speaker used in the SD72WV is the next generation of Atlas high performance cone loudspeakers, very similar to the preceding C-Series speakers.
List Price$41.95
You Save18%
$34.50
Part # 242-9406
  • 10 oz. speaker provides familiar response & performance
  • Attractive CRS white powder coat baffle with center mounted volume control
  • Incorporate or remove volume control knob to suit application requirements
  • Individually packaged for stocking & ordering convenience
  • Quality 5 watt-dual voltage transformer
The speaker used in the SD72WV is the next generation of Atlas high performance cone loudspeakers, very similar to the preceding C-Series speakers. The similarity in the sonic qualities ensures that contractors and designers who have worked with the Atlas Sound C-Series in the past will know exactly what to expect when they use the SD72WV. Model SD72WV is a 25 watt 8" (205 mm) loudspeaker with a 10 oz. (260 g) ceramic magnet. It includes a curvelinear, treated paper cone for lower harmonic distortion. The loudspeaker is also equipped with a full 1" diameter copper voice coil with a black anodized aluminum former for better power dissipation. Model SD72WV operates within a frequency response range of 45 Hz-19 kHz (nominal) with a sensitivity of 97 dB and a dispersion angle of 105°. Package includes factory installed 25/70.7V line matching transformer with tap selections ranging from .25 to 5 watts.
The SD72WV includes a factory installed CRS baffle with concealed loudspeaker mounting studs and includes screw mount hardware. The SD72WV baffle features standard mounting holes to accommodate the majority of Atlas Sound 8" tile bridges, mounting rings and enclosures.
When specifying mounting hardware be advised that the dimensions of the SD72WV baffle match the Atlas Sound Model 62-8. The baffle finish is white powder coat epoxy. The baffle mounted volume control has a 5 watt audio rating and is factory wired to the voice coil. Units are shipped assembled, ready for installation.
Specifications: • Depth: 2-7/8" (7.30 cm) • Diameter: 8-1/8" (20.64 cm) • Shipping weight: 5.63 lbs. (2.55 kg) • Frequency response: 100 Hz-10 kHz (±1.5 dB) • Power taps: .25, .5, 1, 2, 5 • Speaker type: Treated paper • Dispersion: 105° (2 kHz Octave Band, -6 dB Points) • Sensitivity: 97 dB Average • UL listed/standard: 1480, 2043.
  • Input Rating70V,25V
  • Mounting StyleIn-ceiling
  • Special FeaturesUL1480,UL2043,Volume Control
  • Woofer Diameter8"
  • BrandAtlas Sound
  • ModelSD72WV
  • Part Number242-9406
  • UPC612079179961
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
    (2 Reviews)
  • Weight4.75 lbs.
View similar products to the Atlas Sound SD72WV 8" Ceiling Speaker with Volume Control
in the In-Ceiling / On-Ceiling Speakers product category.
Atlas Sound SD72WV 8" Ceiling Speaker with Volume Control is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from Atlas Ceiling SpeakersReceived my order faster than expected. Installed in a car dealership and works great.
Date published: 2013-09-11
Rated 5 out of 5 by from It's cheap, it works, enough said.It's a cheap celling speaker for a 70v paging system. Does it sound like a $1000 Bose/Harmon Kardon/etc... No. It works well for paging and background music. It has multiple taps for various wattages, and it has a volume adjustment to fine tune it. The only thing I would have liked was a single set of inputs and some kind of selector switch for what wattage I wanted. The multiple wires aren't hard to set up though.Easy install, works very well. I can't ask for much more.
Date published: 2013-04-09
  • 2016-02-10T06:49CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_242-9406, PRD, sort_mostRecent
What is the impedance of the “Atlas Sound SD72WV 8" Ceiling Speaker”? Is it compatible with the “Wired Home MSDB-8 Multi Speaker Distribution Box” part number 300-600?
Asked by: Fish Camp
This is an 8 Ohm speaker with a 70 volt transformer on it to be used with 70v systems. The 300-600 is meant to be used with 4 or 8 ohm speakers. If you bypass the 70v transformer than yes you could use it.
Answered by: TomI
Date published: 2015-02-02
Can the atlas sd72wv be used with the 8 ohm Wired Home MSDB-8 Multi Speaker Distribution Box
Asked by: Tony631
Yes, but the transformer and volume control would have to be bypassed for this.
How far apart are the screw holes diagonally?
Asked by: CharlesGwynn
The screw holes are 11-1/4" apart.
Date published: 2014-10-24
  • 2016-02-10T07:40CST
  • loc_en_US, sid_242-9406, PRD, sort_recentQuestionsFirst
