Atlas Sound PD60A 60W Compression Driver 16 ohms
Brand:|Model: PD60A|Part # 242-9389
Model PD60A is a fully environment-resistant 60 watt driver for indoor or outdoor application recommended for use in expansive and/or high ambient sound-level areas.
- Order Soon - Only 2 Left In StockMore Due In August 4, 2016
List Price$215.99
You Save20%
$172.99
Part # 242-9389
  • Driver provides Accurate Sound Reproduction, Optimum Intelligibility And Dependable Performance
  • Perfect For High Power Public Address Systems
  • Use With CJ-46 BIA100 And DR Series Horns
Model PD60A is a fully environment-resistant 60 watt driver for indoor or outdoor application recommended for use in expansive and/or high ambient sound-level areas. Unit features magnetic-structure components machined to optimum tolerances, 2" voice coil and a plane wave frequency response of 100 - 3,700 Hz (+5 dB). Model PD60A provides screw-type terminals for matching direct to the 16 ohm voice coil impedance. Corrosion-resistant terminal connections are protected by a transparent, impact-resistant plastic cover which provides strain relief for the interconnecting cable. The PD60A is terminated in standard 1-3/8" - 18" thread male couplings for use with screw-on horns.
Specifications: • Height: 6-7/8" (17.46 cm) • Diameter: 6-3/8" (16.19 cm) • Shipping weight: 8.66 lbs (3.93 kg) • Frequency response: 100 - 3,700 Hz • Impedance: 16 ohms • Power rating: 60W • Sensitivity: 112.7 (avg) 100 - 3,700 Hz.
  • BrandAtlas Sound
  • ModelPD60A
  • Part Number242-9389
  • UPC612079161706
  • Product CategoryPA Horn Drivers
  • Weight6.7 lbs.
View similar products to the Atlas Sound PD60A 60W Compression Driver 16 ohms
in the PA Horn Drivers product category.
