Atlas Sound M1000 8" Masking Speaker System Black
Brand:|Model: M1000|Part # 242-9379
The M1000 masking speaker assembly (black) is designed to accurately reproduce the required spectrum of masking signal into the plenum space.
List Price$66.99
You Save19%
$53.99
Part # 242-9379
  • 734 cubic inch enclosure for extended low frequency response
  • Black epoxy finish blends with open ceiling plans
  • Design enables upward, downward and side firing sound dispersion
  • Innovative input panel includes combination knock-out and strain relief connector
  • Labor-saving hardware package comes with new snap hanger assembly allows quick & easy installation
  • Plenum Rated
  • Pre-assembled unit includes 8" dia. loudspeaker, transformer, enclosure, baffle & mounting hardware
The M1000 masking speaker assembly (black) is designed to accurately reproduce the required spectrum of masking signal into the plenum space. The innovative 734 cubic inch square enclosure ensures ample low frequency response. A specially designed 8" dual cone loudspeaker is included in the package. A high efficiency 70.7V internal transformer is coupled to an external tap selector switch for easy system tuning.
To meet most any local code requirement, the M1000 includes an innovative cover containing both knockouts and a strain relief. This system will allow the use of rigid or flexible conduit (if required) and easily accommodates "through" connections on the removable plate. UL 2043 listed for use in air handling spaces.
Specifications: • Height: 5-1/2" (13.97 cm) • Width: 110-9/16" (29.37 cm) • Depth: 110-9/16" (29.37 cm) • Shipping weight: 10.00 lbs. (4.54 kg) • Frequency response: 100 Hz - 10 kHz, ± 1.5 dB • Power taps: .25, .5, 1, 2 and 4 • Speaker type: 8" Dual cone • Dispersion: Upward, downward, horizontal • Sensitivity: 97 dB Peak, 94 dB average • UL listed/standard: 1480, 2043.
  • Input Rating70V
  • Mounting StyleSuspended / Pendant
  • Special FeaturesUL1480,UL2043,Sound Masking
  • Woofer Diameter8"
  • BrandAtlas Sound
  • ModelM1000
  • Part Number242-9379
  • UPC612079179930
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Weight9.3 lbs.
View similar products to the Atlas Sound M1000 8" Masking Speaker System Black
in the In-Ceiling / On-Ceiling Speakers product category.
