Atlas Sound GD87 8" Coaxial Loudspeaker
Brand:|Model: GD87|Part # 242-9374
The high-quality, 25 watt GD87 utilizes a post mounted tweeter which adds strength to the assembly and provides an attractive appearance.
List Price$44.99
You Save20%
$35.99
Part # 242-9374
  • Individually packaged for stocking & ordering convenience
  • Industry standard 8" (203 mm) coaxial, 16 watt loudspeaker
  • High quality factory installed 8 watt line matching transformer
  • Offers proven performance with wide frequency response
  • Post-mounted tweeter adds strength and a more attractive appearance
The GD87 is a high performance coaxial loudspeaker with performance specifications identical to the legendary Atlas Sound Model C803A. This similarity in sonic quality insures that existing C803A systems may be expanded with the new GD87 without any noticeable sonic or performance differences. The high-quality, 25 watt GD87 utilizes a post mounted tweeter which adds strength to the assembly and provides an attractive appearance. This coaxial loudspeaker features a 45 Hz-19 kHz (nominal) frequency response and a broad, uniform dispersion pattern of 105° (2 kHz octave band). The GD87 combines a full-size 8" (203 mm) dia., low-frequency reproducer and a 3" (76 mm) high-frequency reproducer. The two sections are coupled via a built-in crossover network. The woofer has a 10 oz. (260 g) ceramic magnet; the tweeter has a 2.35 oz. (67 g) ceramic magnet. The unit has an average sensitivity of 96 dB (1W/1M). The loudspeaker is matched with a high efficiency 8 watt 70.7V transformer with a maximum insertion loss of 0.6 dB. This premium transformer is constructed of audio grade laminations and has a full range frequency response of +1 dB from 50 Hz to 15 kHz. The primary taps are 1, 2, 4, and 8 watts.
Specifications: • Depth: 2-7/8" (7.30 cm) • Diameter: 8-1/8" (20.64 cm) • Shipping weight: 4.33 lbs. (1.96 kg) • Frequency response: 55 Hz-15 kHz (±7 dB) • Power taps: 1, 2, 4, 8 • Speaker type: Treated paper • Dispersion: 105° (2 kHz Octave Band, -6 dB Points) • Sensitivity: 96 dB average • UL listed/standard: 1480, 2043.
  • Input Rating70V
  • Mounting StyleIn-ceiling
  • Special FeaturesUL1480,UL2043
  • Woofer Diameter8"
  • BrandAtlas Sound
  • ModelGD87
  • Part Number242-9374
  • UPC612079179978
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Weight3.45 lbs.
View similar products to the Atlas Sound GD87 8" Coaxial Loudspeaker
in the In-Ceiling / On-Ceiling Speakers product category.
