242-804_ALT_0
Atlas Sound FAP42TC 4" Speaker System Pair
Brand:| Model: FAP42TC
With an overall depth of 4" the FAP42TC is the perfect choice when high fidelity audio and wide, even coverage is required but space above the plenum is limited.
  • Easy installation in drop tile or sheetrock ceilings via included C-ring/V-rail tile bridge
  • Also incorporates "dog leg" mounting system
  • Front mounted tap selector switch for easy system tuning adjustments
  • Includes transformer bypass setting for 8 ohm direct coupled operation
  • Extended low frequency response from the optimally tuned and ported deep galvanized steel enclosure
  • 4-pole detachable "phoenix" style connector allows for easy pre-wiring and daisy chaining
  • Enhanced quality 70.7V/100V internal transformer minimizes insertion loss and maintains LF response
242-804
Weight: 10 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
List Price$233.90
You Save19%
$189.00
Part # 242-804
Qty:  PR
Atlas Sound's Strategy Series® II premium ceiling speaker packages will satisfy the needs of owners, architects, contractors, and consultants by delivering true, high fidelity sound reproduction in an attractive and easy-to-install system. These high-performance systems are perfectly suited for many business music and public address applications. Each speaker system ships complete with speaker/transformer factory assembled into back can, grill, and unique C-ring/V-rail mounting hardware. Sold in pairs, priced per pair. With an overall depth of 4" (102 mm) the FAP42TC is the perfect choice when high fidelity audio and wide, even coverage is required but space above the plenum is limited. For wall mount applications (tanning salons or surround sound) the short 4" depth will even work in most stud wall installations.
Specifications: • Power rating: 16 watts (transformer limited) • 70.7V Taps: 1, 2, 4, 8, 16 watts • Frequency response: 75 Hz-20 kHz • Dispersion: 130° • Dimensions: Overall: 10-1/2" dia. x 4-1/4" H; Cutout: 9" dia.
  • Input Rating8 ohm,70V,100V
  • Mounting StyleIn-ceiling
  • Special FeaturesEnclosed Back,UL1480
  • Woofer Diameter4"
  • BrandAtlas Sound
  • ModelFAP42TC
  • Part Number242-804
  • UPC612079181209
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Unit of MeasurePR
    (1 Reviews)
  • Weight10 lbs.
View similar products to the Atlas Sound FAP42TC 4" Speaker System Pair
in the In-Ceiling / On-Ceiling Speakers product category.
Atlas Sound FAP42TC 4" Speaker System Pair is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Good SpeakerThese speakers are very pleasant sounding. They can play quite loud if needed without distorting. Metal back can makes them OK for plenum ceilings.
Date published: 2009-03-05
  • 2015-02-28T06:52CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_242-804, PRD, sort_mostRecent
Customer projects that include: Atlas Sound FAP42TC 4" Speaker System Pair
