Atlas Sound FA97-6 6" Recessed Ceiling Speaker Enclosure with Dog Legs
Brand:|Model: FA97-6|Part # 242-9365
Model FA97-6 installs quickly and easily in plaster, drywall, or suspended tile ceilings up to 2-1/4" thick utilizing three, easy-to-adjust rotating clamps that rotate and secure into position with a screwdriver.
List Price$48.95
You Save17%
$40.50
Part # 242-9365
  • Acoustically treated enclosure for Strategy I speakers
  • Depth of enclosure allows for extended low frequency response
  • Flip tab dog ears allow for installation in ceilings up to 2-1/4" thick
  • Recessed lip in opening mounts speaker directly to enclosure to provide a sealed system
  • Tubular spring clips on flanged face accept ribbed weld studs on Strategy I grills
  • UL1480 and UL2043 listed for use in General Signaling and Plenum ceilings
Model FA97-6 installs quickly and easily in plaster, drywall, or suspended tile ceilings up to 2-1/4" thick utilizing three, easy-to-adjust rotating clamps that rotate and secure into position with a screwdriver. The enclosure front-loads Atlas Sound's Strategy Series 6" dia. loudspeaker Models FA136 and FA116. This direct loudspeaker to enclosure mounting method removes all load-bearing requirements from the grille, allowing the use of welded studs for convenient, push-on grille installation — a time-saving feature which presents a clean and hardware-free appearance. It also facilitates fast and easy grille removal for painting or other maintenance. The FA97-6 allows the high-performance coaxial FA136 loudspeaker to achieve maximum potential. This high-quality loudspeaker/enclosure combination is perfect for applications where high-fidelity music and intelligible speech are imperative.
Specifications: • Depth: 7 5/8" (19.37 cm) • Diameter: 7" (17.78 cm) • Shipping weight: 2.83 lbs. (1.29 kg) • UL listed/standard: 1480, 2043.
  • BrandAtlas Sound
  • ModelFA97-6
  • Part Number242-9365
  • UPC612079113606
  • Product CategorySpeaker Back Boxes & Enclosures
  • Weight4.2 lbs.
View similar products to the Atlas Sound FA97-6 6" Recessed Ceiling Speaker Enclosure with Dog Legs
in the Speaker Back Boxes & Enclosures product category.
