Atlas Sound ECS-3 15 Amp Power Sequencer/Conditioner
Brand:|Model: ECS-3|Part # 242-9462
The ECS-3 has been designed to meet most installation requirements for AC power distribution and equipment power protection. The 15A compact 1 RU unit features three sequential timing sections that can be activated via the unit, or remotely.
ORDER TODAY
Ships in 7-10 Business Days
List Price$515.99
You Save20%
$412.99
Part # 242-9462
  • 6 Rear Panel Outlets are Sequenced in Three Stages
  • 2 Front Panel and 1 Rear Panel Unswitched Convenience Outlets
  • Radio Frequency and Electromagnetic Interference Filters
  • Dual Clamping Spike & Surge Suppression, DCS Circuitry
  • Front Panel Digital AC Mains Voltmeter
  • Extreme Voltage Shutdown (EVS) Below 102V or Above 132V AC Line
  • Front Mounted Pull-out LED Light with 2 Position Dimmer
The ECS-3 has been designed to meet most installation requirements for AC power distribution and equipment power protection. The 15A compact 1 RU unit features three sequential timing sections that can be activated via the unit, or remotely. Front panel activation is via a momentary switch, while rear activation is via a momentary contact closure, or by 5-24VDC trigger feed. AC Mains Voltage can be monitored via the front panel from the precision Digital Volt Meter. To light your rack, the ECS-3 has incorporated a front panel pull-out dimmable LED tube light. The rear of the rack can be illuminated by the optional 18" gooseneck LED lamp connected via an XLR style socket. LED lamps are far superior in longevity along with heat reduction when compared to traditional incandescent lamps and the XLR base mounts are also superior to the commonly used BNC type base. If a 15A AC Mains power source is not enough to meet the amperage demand of your system, the ECS-3 provides a sequenced 24VDC output that can be used to trigger other devices such as the Atlas Sound ECM-20SH 20A stand alone AC power module.
Specifications: • Current rating: 15 Amps • Operating voltage: 102-132VAC • Minimum spike clamping voltage: 460 VRMS @ 3000A • Maximum spike clamping voltage: 6000V • Power consumption: 12 watts • Height: 1.75" (44.5 mm) • Width: 19" (482.6 mm) • Depth: 8.5" (215.9 mm) • Certifications: MET (UL 1449).
  • Number of Outlets8
  • Special FeaturesRack Mountable
  • Cord Length5 ft.
  • ColorBlack
  • BrandAtlas Sound
  • ModelECS-3
  • Part Number242-9462
  • UPC612079186303
  • Product CategoryRack Mount Power Distribution
  • Weight1 lbs.
View similar products to the Atlas Sound ECS-3 15 Amp Power Sequencer/Conditioner
in the Rack Mount Power Distribution product category.
