Atlas Sound DR-72 Uniform Coverage PA Horn Paging Speaker 65 degree
Brand:|Model: DR-72|Part # 242-9354
Atlas Sound DR Series double re-entrant horns are designed for use with compression driver units to offer superior music and voice communications over distance and ambient noise.
Part # 242-9354
  • Accepts All Standard High Efficiency Compression Drivers with 13/8" - 18 Male Threads
  • Exponentially-Flared for Uniform Sound Distribution
  • Multi-Purpose Reflex Sound Horns for High Intelligibility Sound Distribution & Voice Applications
  • Weatherproof, All-Metal Construction for Year Round Use
Atlas Sound DR Series double re-entrant horns are designed for use with compression driver units to offer superior music and voice communications over distance and ambient noise. The circular projectors are equipped with a resonance damping ring for best response through an extended frequency range. Weather-resistant units will accommodate Atlas Sound PD and SD Series compression drivers or any driver with standard 1-3/8" -18 male thread coupling. The rugged all-metal, exponentially-flared horns are finished in durable gray epoxy. The integral "U-type" steel mounting bracket provides maximum directional aiming flexibility and enhances installation capability when used outdoors or in industrial environments.
Specifications: • Depth: 28" (71.12 cm) • Diameter: 31" (78.74 cm) • Shipping weight: 25.00 lbs (11.34 kg) • Dispersion: 65°.
  • BrandAtlas Sound
  • ModelDR-72
  • Part Number242-9354
  • UPC612079112357
  • Product CategoryPA Horns
  • Weight25 lbs.
View similar products to the Atlas Sound DR-72 Uniform Coverage PA Horn Paging Speaker 65 degree
in the PA Horns product category.
