Atlas Sound CP700 Commercial Duty Power Amplifier
Brand:|Model: CP700|Part # 242-925
Whether your application is a large distributed constant voltage sound system or a high SPL sound reinforcement system, the Atlas Sound CP700 is the perfect answer for high power/low cost amplification needs. • Power output: 400 watts x 2 (4 ohms), 350 watts x 2 (70.7V/100V)
List Price$976.99
You Save20%
$781.99
Part # 242-925
  • Stereo, bridge, or parallel operating modes selectable via rear mounted switch
  • Balanced inputs on barrier strip and XLR connectors
  • Short-circuit, temperature, and DC offset protection
  • 25V, 70.7V, 100V, and direct-coupled barrier strip outputs
  • Soft clip limiter protection
  • Power-up muting
  • Automatic, dual-speed, high efficiency fan cooling
Whether your application is a large distributed constant voltage sound system or a high SPL sound reinforcement system, the Atlas Sound CP700 is the perfect answer for high power/low cost amplification needs. A professional grade audio power amplifier specifically designed for demanding contractor applications, the CP700 features esoteric grade toroidal power supply and output transformers. These transformers were chosen for their outstanding reliability as well as extended frequency response. Plus, the CP700's two independent channels are driven by separate power supplies to ensure maximum channel separation and ultra low distortion figures while providing years or faithful service.
Specifications: • Power output: 240 watts x 2 (8 ohms), 400 watts x 2 (4 ohms), 550 watts x 2 (2 ohms) • Bridged mono: 850 watts x 1 (8 ohms); 1,100 watts (4 ohms) • Transformer outputs: 280 watts x 2 (25V), 350 watts x 2 (70.7V/100V), 700 watts x 1 (140V/200V Bridged) • Frequency response: Direct: 30 Hz-50 kHz; Transformer: 30 Hz-16 kHz • S/N ratio: >100 dB • Voltage gain: 32 dB • Damping factor: >200 dB • Net weight: 54 lbs. • Dimensions: 18.9" W x 5.19" H x 16.85" D • Mfg. #CP700.
  • Power Output (RMS @ 70V)201W to 400W
  • Weight Range50 to 59 lbs.
  • BrandAtlas Sound
  • ModelCP700
  • Part Number242-925
  • UPC612079182572
  • Product CategoryCommercial Contractor Power Amplifiers
    (1 Reviews)
  • Weight62 lbs.
View similar products to the Atlas Sound CP700 Commercial Duty Power Amplifier
in the Commercial Contractor Power Amplifiers product category.
