Atlas Sound APF-15TU 15 Watt Emergency Signaling Loudspeaker
Brand:|Model: APF-15TU|Part # 242-9342
APF-15TU voice control loudspeaker is equipped with a compression driver to provide up to 15 watts of continuous power handling, superior intelligibility and audio conversion efficiency for maximum sound projection and penetration.
  • Choose from matching grilles, enclosures and mounting. Rings (order separately)
  • Double re-entrant design provides superior audibility of voice and tone signaling
  • High-efficiency, 15 watt compression driver with proven record of outstanding service reliability
  • May be flange or recess mounted
  • Transformer(T) equipped version for 25, 70.7, or 100V line
  • Vandal and environment-resistant metal construction for outdoor or indoor use
  • Not equipped with a capacitor
APF-15TU voice control loudspeaker is equipped with a compression driver to provide up to 15 watts of continuous power handling, superior intelligibility and audio conversion efficiency for maximum sound projection and penetration. APF Series loudspeakers may be flush mounted or recessed directly into interior/exterior walls or ceilings. Recessed installation may be accomplished by mounting loudspeakers into a 5-1/2" deep opening or recessed enclosure. Units will facilitate Atlas Sound L20 Series grilles, enclosures and mounting rings (refer to SL2-1372). Accessory mounting kits Model MK-2 or FAMT-6 can be used to mount loudspeakers into 8" diameter baffles. Finished in gray baked epoxy.
Model includes a built-in 25/70.7V Vari-Tap transformer featuring a screw-driver adjustable, 7-position watt/impedance selection switch. Magnet assembly is equipped with self-aligning field replaceable diaphragm. Wiring terminals are protected with a vandal-resistant adapter cover for control equipment utilizing cable or conduit.
All models meet or exceed UL Standard 1480 for Fire Protective Loudspeakers and are capable of operating within an ambient temp. range of 66°C (150°F) to -35°C (-30°F).The all-metal, environment resistant construction and re-entrant acoustic path assure protection against water, humidity, vermin, physical abuse and corrosion. Models are also California State Fire Marshal Listed. Models with special modifications to meet other safety authorities are available.
Specifications: • Depth: 50-3/16" (13.18 cm) • Diameter: 5-5/8" (14.29 cm) • Shipping weight: 5.00 lbs (2.27 kg) • Frequency response: 600-14,000 Hz • Impedance: 25, 70.7V • Dispersion: 95° • Power rating: 15 watts • Sensitivity: 104 dB • UL Listed/Standard: 1480 • Operating temperature range: -40 to 70°C.
  • Speaker TypePA Horn Speaker
  • BrandAtlas Sound
  • ModelAPF-15TU
  • Part Number242-9342
  • UPC612079110568
  • Product CategoryPA Horn Speakers for Music & Paging
  • Weight5 lbs.
View similar products to the Atlas Sound APF-15TU 15 Watt Emergency Signaling Loudspeaker
in the PA Horn Speakers for Music & Paging product category.
