Atlas Sound APF-15T 15 Watt Loudspeaker with Transformer
Brand:| Model: APF-15T
Provide 15 watts of continuous power handling with superior intelligibility and efficiency with Atlas Sound APF Series Omni-PurposeĀ® loudspeakers.
  • Choose from matching grilles, enclosures and mounting. Rings (order separately)
  • Double re-entrant design provides superior audibility of voice and tone signaling
  • High-efficiency, 15 watt compression driver with proven record of outstanding service reliability
  • May be flange or recess mounted
  • Transformer(T) equipped version for 25, 70.7, or 100V line
  • Vandal and environment-resistant metal construction for outdoor or indoor use
242-9341
Weight: 4 lbs.
ORDER TODAY
Ships in 7-10 Business Days
List Price$117.95
You Save19%
$95.50
Part # 242-9341
Provide 15 watts of continuous power handling with superior intelligibility and efficiency with Atlas Sound APF Series Omni-Purpose® loudspeakers. Vandal-resistant units are designed for flange or recessed mounting to panels, interior/exterior walls, or ceilings. Loudspeakers are finished in gray baked epoxy. Metal construction withstands adverse temperatures, humidity and physical abuse. For flexibility and optimum adjustment convenience, transformer-equipped Model APF-15T includes the Vari-Tap® Control/connect center with 7 position, wattage/impedance selection switch.
Weather-resistant metal construction and enclosed wiring terminals eliminate the need and cost of a backbox. However, for aesthetic consideration and retrofit convenience, models will flange mount to any standard size ceiling or wall baffle and/or enclosure capable of accommodating conventional 6" or 8" diameter loudspeakers. Model FAMT-6 mounting kit is required for 8" models. Recessed installation may be accomplished by mounting Models APF-15 or APF-15T into a 4" or 5 1/2" deep opening, respectively, or to an L20 Series enclosure. L20 Series also includes mounting rings and baffles.
Specifications: • Depth: 5-3/16" (13.18 cm) • Diameter: 5-5/8" (14.29 cm) • Shipping weight: 4.00 lbs (1.81 kg) • Frequency response: 600-14,000 Hz • Power taps: 1, 2, 3.8, 7.5, 15W @ 70.7V • Dispersion: 95° • Power rating: 15 watts • Sensitivity: 104 dB • UL listed/standard: 1480.
  • Speaker TypePA Horn Speaker
  • BrandAtlas Sound
  • ModelAPF-15T
  • Part Number242-9341
  • UPC612079110537
  • Product CategoryPA Horn Speakers for Music & Paging
  • Weight4 lbs.
View similar products to the Atlas Sound APF-15T 15 Watt Loudspeaker with Transformer
in the PA Horn Speakers for Music & Paging product category.
Customer projects that include: Atlas Sound APF-15T 15 Watt Loudspeaker with Transformer
