Atlas Sound APC-30T Wide Angle Omni-Purpose Loudspeaker
Brand:|Model: APC-30T|Part # 242-9340
APC-30T is a high-power 30 watt loudspeaker with extended low frequency response. Unit is equipped with a wide-angle molded plastic bell for sound directivity.
OUT OF STOCK
Due In: 9/29/2016
List Price$201.99
You Save20%
$160.99
Part # 242-9340
  • High-Powered Compression Driver Projects Superior Voice and Tone Signaling
  • Includes a 25, 70.7, 100V Transformer with a 45 ohm Tap
  • One-Step Method of Adjusting Bell from Horizontal to Vertical Positioning
  • Wide-Angle Sound Dispersion for Maximum Horizontal Pattern Coverage
APC-30T is a high-power 30 watt loudspeaker with extended low frequency response. Unit is equipped with a wide-angle molded plastic bell for sound directivity. Transformer includes a screwdriver-adjust power selection with a 45 ohm tap for intercom and talk-back use. For mounting, the APC-30T features the Omni-Purpose® bracket for vertical/horizontal positioning with provisions for surface/strap mounting to pillars and I-beams. Finished in gray baked epoxy.
Specifications: • Height: 8-1/4" (20.96 cm) • Width: 14-3/8" (36.51 cm) • Depth: 12-7/8" (32.70 cm) • Shipping weight: 9.00 lbs (4.08 kg) • Frequency response: 300 - 12,000 Hz • Power taps: 2, 3.8, 7.5, 15, 30W @ 70.7V • Dispersion: 70° x 95° • Power rating: 30 watts • Sensitivity: 109 dB.
  • Speaker TypePA Horn Speaker
  • BrandAtlas Sound
  • ModelAPC-30T
  • Part Number242-9340
  • UPC612079110513
  • Product CategoryPA Horn Speakers for Music & Paging
  • Weight7.95 lbs.
View similar products to the Atlas Sound APC-30T Wide Angle Omni-Purpose Loudspeaker
in the PA Horn Speakers for Music & Paging product category.
