Atlas Sound AH94-8T-BSG 8" 2-Way Stadium Horn Speaker System
Brand:|Model: AH94-8T-BSG|Part # 242-9332
Atlas Sound model AH94-8ST "stadium horn" is ideal for directional sound distribution where full range reproduction, maximum intelligibility and high sound pressure levels are required.
ORDER TODAY
Ships in 7-10 Business Days
List Price$947.99
You Save20%
ShippingTRUCK ONLY
$758.99
Part # 242-9332
  • (3) Forged eyebolts also included for suspended installation
  • 100 watts power handling
  • Constant Directivity design offers controlled coverage of 90° horizontal by 40° vertical
  • Driver compliment includes 8" cast frame woofer with 1" exit compression driver coupled to HF horn
  • Easy, weather resistant connection via a convenient recessed terminal block
  • Efficiency rating of 101 dB (1W/1M)
  • Heavy duty mounting bracket allows for easy installation to flat surface
Atlas Sound model AH94-8ST "stadium horn" is ideal for directional sound distribution where full range reproduction, maximum intelligibility and high sound pressure levels are required. Applications include football stadiums, sports arenas, baseball fields, convention centers and auditoriums. Weather resistant construction features of the AH94-8ST include a multiple screen configuration to prevent moisture from damaging internal components, a perforated aluminum screen covers the large horn mouth, a secondary screen is in place forward of the high frequency driver and a third tightly perforated screen protects the 8" cast frame woofer. A "weep" hole is also included on the back of the large horn "bell" to allow evaporation of any condensation that might build up internally.
Specifications: • Height: 20.05" (509.27 mm) • Width: 19.66" (499.36 mm) • Depth: 19.73" (501.14 mm) • Shipping weight: 100 lbs. (45.36 kg) • Transformer power taps: 7.5, 15, 30 & 60 watts • Driver type: 1" HF and 8" LF • Dispersion: 90° x 90° • Power rating: 100 watts • Sensitivity: 101 dB SPL (70 Hz to 17 kHz 1/3 octave bands) • Frequency Response: 90 Hz - 15 kHz (±5 dB).
  • Speaker TypeStadium Horn System
  • BrandAtlas Sound
  • ModelAH94-8T-BSG
  • Part Number242-9332
  • UPC612079189878
  • Product CategoryPA Horn Speakers for Music & Paging
  • Weight100 lbs.
View similar products to the Atlas Sound AH94-8T-BSG 8" 2-Way Stadium Horn Speaker System
in the PA Horn Speakers for Music & Paging product category.
