Atlas Sound AH66-15-BSG 15" 2-Way Stadium Horn Speaker System
Brand:|Model: AH66-15-BSG|Part # 242-9327
Atlas Sound model AH66-15-BSG "stadium horn" is ideal for directional sound distribution where full range reproduction, maximum intelligibility and high sound pressure levels are required.
  • (3) Forged eyebolts also included for suspended installation
  • 250 watts power handling
  • 8-ohm nominal system impedance 70.7 volt operation via optional Atlas Sound model AF140 transformer
  • Constant Directivity design offers controlled coverage of 65° horizontal by 65° vertical
  • Driver compliment includes 15" cast frame woofer w/a mounted 1" exit compression driver & HF horn
  • Easy, weather resistant connection via a parallel 4-pole terminal block connector
  • Efficiency rating of 104dB (1 watt/1 Meter)
Atlas Sound model AH66-15-BSG "stadium horn" is ideal for directional sound distribution where full range reproduction, maximum intelligibility and high sound pressure levels are required. Applications include football stadiums, sports arenas, baseball fields, convention centers and auditoriums. Weather resistant construction features of the AH66-15-BSG include a multiple screen configuration to prevent moisture from damaging internal components. A perforated aluminum screen covers the large horn mouth, a secondary screen is in place forward of the high frequency driver and a third tightly perforated screen protects the 15" cast frame woofer. A "weep" hole is included on the back of the large horn "bell" to allow evaporation of any condensation that might build up internally.
Specifications: • Frequency response: 75 Hz - 14.5 kHz (±5 dB) • Driver type LF: (1) 15 • Dispersion: 65° x 65° • Power rating: 250 watts (53V) RMS • Sensitivity: 104 dB SPL (70 Hz to 17 kHz 1/3 octave bands) • Color: Battleship grey • Height: 20-1/2" (52.07 cm) • Width: 20-1/2" (52.07 cm) • Depth: 32" (81.28 cm) • Shipping weight: 125.00 lbs (56.70 kg).
  • Speaker TypeStadium Horn System
  • BrandAtlas Sound
  • ModelAH66-15-BSG
  • Part Number242-9327
  • UPC612079189809
  • Product CategoryPA Horn Speakers for Music & Paging
  • Weight125 lbs.
View similar products to the Atlas Sound AH66-15-BSG 15" 2-Way Stadium Horn Speaker System
in the PA Horn Speakers for Music & Paging product category.
