BUYOUT
129-004_ALT_0
129-004_ALT_1
129-004_ALT_2
129-004_ALT_3
Astec 12 VDC 24A 288W Regulated and Filtered Power Supply with Case and Accessories
Brand:|Model: AA21660|Part # 129-004
Built to exacting IBM standards for powering data center storage servers, this 12 VDC Astec power supply has been fitted to a strong, aluminum case for hobbyist applications or to be used as a bench top reference power supply. Save over 40% off the original retail price of the power supply by itself!
List Price$100.00
You Save41%
$59.00
Part # 129-004
  • High output power: 400 watts max instantaneous, 288 watts RMS continuous
  • Robustly built to IBM specifications for powering 12 VDC storage servers
  • Includes 6 foot IEC power cable and 6 foot coiled cigarette lighter adapter with 2.1 mm right angle, center-negative tip
  • Heavy-duty, 1/4" thick binding posts and cigarette lighter socket for output
  • World-compatible design works with 100 to 240 VAC input power
  • cULus listed and TUV approved design
Astec built this 12 VDC regulated and filtered power supply to output 288 watts continuously, and 400 watts peak for powering critical IBM storage servers. This power supply was then fitted to a durable steel case, in the USA, for use in many hobbyist applications: model railroads, slot car racing, power for amplifier boards, science experiments, and much more. It also works great in electronics labs as a reference bench top power supply.
Based on a world-compatible design, the power supply senses input voltage and works with 100 to 240 VAC mains power, 50/60 Hz, and consumes up to 700 watts of power during peak output. Active fault monitoring for short circuit and over-current conditions is built-in, protecting the power supply from failure. Not only is this power supply cULus recognized, it also meets TUV criteria for approval.
Power output is provided by two 1/4" thick binding posts, which are wired in parallel with the chassis mounted cigarette lighter socket. A coiled six foot, 2.5A fuse-protected cigarette lighter adapter with 2.1 x 5.5 mm right angle, center-negative plug (with power indication) is included for powering mobile accessories; a six foot 18/3 IEC power cable is also included.
Save over 40% off the original retail price of the power supply alone through this Parts Express exclusive buyout. Hurry, supplies are limited! If you need higher voltage, use the power supply with this DC to DC step-up voltage booster.
Note: This power supply has been internally tested at Parts Express to supply the advertised continuous and peak power ratings using an adjusted 320-3376, to step up the voltage to 50 VDC, for powering the 320-309 amplifier board, with reference level sine waves for signal input, and connected to two four ohm transducers wired in parallel for a 2 ohm load.
Specifications: • Input power: 100-240 VAC, 50/60 Hz • Maximum power consumption: 700 watts • Power output: 12 VDC, 24A (288 watts RMS continuous, 400 watts maximum instantaneous) • Dimensions: 14-1/2" L (including binding posts, 13-3/4" case only) x 6" W x 3-1/2" H.
  • BrandFactory Buyouts
  • ModelAA21660
  • Part Number129-004
  • UPC759377380948
  • Product CategoryPower Supplies
    (8 Reviews)
  • Weight11.7500 lbs.
View similar products to the Astec 12 VDC 24A 288W Regulated and Filtered Power Supply with Case and Accessories
in the Power Supplies product category.
