Ashly XR-1001 Stereo 2-Way/Mono 3-Way Crossover
Brand:|Model: XR-1001|Part # 245-208
The XR Series crossovers all feature 24 dB per octave filters, infinitely variable crossover frequency and response, as well as both 1/4" TRS phone jacks and XLR connectors for all inputs and outputs.
OUT OF STOCK
Awaiting Updated Due Date
List Price$310.00
You Save19%
$250.00
Part # 245-208
  • 24 dB/octave slopes, 20 Hz third order high pass filter
  • Variable filter allows tuning-in Linkwitz-Riley or other filter responses
  • Output mute switches
  • Balanced inputs and outputs
  • XLR and 1/4" TRS audio connections
  • Peak overload warning LEDs
  • Five Year Worry-Free Warranty
The XR Series crossovers all feature 24 dB per octave filters, infinitely variable crossover frequency and response, as well as both 1/4" TRS phone jacks and XLR connectors for all inputs and outputs. A peak overload indicator monitors all critical points in the circuit to ensure low-distortion operation. A recessed switch on the front panel with an LED indicator allows for either Normal or Divide by Ten frequency selection. The XR-1001 is a stereo two-way or mono three-way crossover.
Specifications: • Dimensions: 19" W x 1.75" H x 6" D.
The XR-Series crossovers are the product of an intensive research effort started in 1972 which combined a reexamination of traditional crossover theory with practical field use. Over the years, a number of refinements and new models have been added to our crossover series, but the original design goals have remained the same: to produce a crossover which is sonically accurate, is flexible enough to suit a wide variety of systems, and affords maximum protection for speakers and drivers.
All Ashly crossovers are based upon the same powerful state-variable filter circuit, which guarantees that two adjacent frequency band outputs always remain in phase. Our crossovers offer a number of useful and unusual features, including continuous tuning, a response control, and a unique output stage which maintains low noise at any level setting. These models also include a 200:1 tuning range, output mute switches, and both TRS and XLR connectors. Like other Ashly products, your crossover features low noise and distortion, active balanced inputs, a peak level indicator, a precision regulated power supply, protection against abnormal input or output conditions, and rugged mechanical construction. Conservative design and an unusually thorough procedure for quality control have earned Ashly a reputation for dependability in the recording, sound reinforcement, and broadcast fields.
  • BrandAshly Audio
  • ModelXR-1001
  • Part Number245-208
  • UPC844632051548
  • Product CategoryActive Crossovers
    (3 Reviews)
  • Weight10.5 lbs.
View similar products to the Ashly XR-1001 Stereo 2-Way/Mono 3-Way Crossover
in the Active Crossovers product category.
Ashly XR-1001 Stereo 2-Way/Mono 3-Way Crossover is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from Tri-Amped system using 2 Ashlys. BLOWS ME AWAY.To run a tri-amped system, it is necessary to have 2 of these units, each configured for mono and an amplifier for each band, low, mid & high. One unit needs to be designated as LEFT and the other as RIGHT. Normal stereo inputs and outputs are split amongst the units and crossover points chosen and set on each one. My bass drivers are being crossed at 90hz and the mids are crossing into the tweeters at 2Khz. The slope adjustments allow for tailored crossover response. I have my units set to 6, which corresponds to the Linkwitz Riley spec. The adjustment combinations are infinite so any changes in your amps or speakers can be accommodated very easily. I'm hooked on active crossovers and these Ashly units really fit the bill. They are built like a tank.
Date published: 2014-12-26
Rated 5 out of 5 by from Used in 2 channel mode, has the features I wantedThe system I'm using this crossover in is quite unique. I'm a collector of vintage audio gear and I'm running a Carver C-1 preamp into the Ashly and the 2 output channels (low & high) are going to separate amps, a Carver M1.5t for the bass drivers (which are Dayton ST305-8 12") and a Carver M1.0t for the treble drivers (which are ESS Heil Air Motion that I purchased from Parts Express). The Ashly makes setting everything up so easy. There is a "slope" control that allows adjustment of the way the crossover points interact. I chose to set the slope to the Linkwitz Riley standard and the sound is awesome. I'm running a 1Khz crossover frequency. Seperate level adjustments for each driver allows for any level mismatching due to room location or any other audio aberration that can creep up. I like my volume levels high and with the Ashly in my signal path, I don't need any power robbing passive crossovers to sort out the frequencies for me. Each of the drivers are direct wired straight to the amp output and the Ashly takes it from there. This unit is a wonderful investment for me. If you're considering a bi-amp setup, the Ashly is definitely a winner. Highly recommended.
Date published: 2014-12-08
Rated 4 out of 5 by from Hifi bi-amplified systemUsed the Ashley XR-1001 to biamplify a pair of Cornscalas. Conversion from XLR to unbalanced RCA was done through custom cables using information on Rane web page. System is very quiet, and transparant. Going to a biamplified system with an active crossover greatly improved midrange clarity. Very satisfied.
Date published: 2010-04-05
  • 2016-02-12T06:20CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_245-208, PRD, sort_mostRecent
Can you supply unit with a 230v power supply?
Asked by: kamaruj
This has an internal universal 100-230v power supply.
Date published: 2013-10-07
  • 2016-02-12T06:59CST
  • loc_en_US, sid_245-208, PRD, sort_recentQuestionsFirst
