Ashly MQX-2310 Dual 31-Band EQ 2U
Brand:|Model: MQX-2310|Part # 245-204
The MQX Series equalizer features all the performance and great sound of Ashly's legendary GQX models in a uniquely compact package.
ORDER TODAY
Ships in 7-10 Business Days
List Price$495.00
You Save19%
$399.00
Part # 245-204
  • Precision Wein-bridge filters for accurate response and low distortion
  • Constant "Q" design for low ripple and minimum interaction
  • High quality detented 25 mm metal shaft faders with center-off position
  • Balanced XLR and 1/4" TRS audio connections on all models
  • Barrier strips on MQX-1310 and MQX-2310
  • Selectable 15 dB or 6 dB range
  • 18 dB/octave high pass filter
The MQX Series features all the performance and great sound of Ashly's legendary GQX models in a uniquely compact package. The same exacting filter design and summing circuitry of the GQX Series equalizers are utilized, with each filter exhibiting true constant Q response. Housed in a rugged steel chassis, each model features balanced inputs and outputs, with full ground lift provisions. Finally, a truly professional graphic equalizer in a smaller rack space package! Dimensions: 19" W x 3.5" H x 6" D.
Audio engineers do not have to give up a lot just to save a little rack space when choosing an equalizer. Ashly believes that engineers should never have to compromise their standards just for the sake of miniaturization. They proudly offer the MQX Series, featuring all the performance and great sound of their legendary GQX models in a uniquely compact package.
The same exacting filter design and summing circuitry of the GQX Series equalizers are utilized, with each filter exhibiting true constant Q response. The center detented position of every fader acts as an on/off switch for its filter to minimize any possible degradation to signal noise levels. Even the faders themselves put these MQX Series models into a class all their own. Instead of the 20 mm plastic faders typically used by the competition, Ashly has selected a custom-manufactured 25 mm slide fader device. The additional range and accuracy of this component allow us to offer up to ±15 dB of boost or cut adjustment on each individual filter (an Ashly exclusive in this class of product).
Housed in a rugged steel chassis, each model features balanced inputs and outputs, with full ground lift provisions. For those engineers looking to avoid those pesky "wall warts", you will be pleased to find that we feature internal power supplies in all Ashly products.
Of course, each MQX Series equalizer is covered by an exclusive Five Year Worry Free Warranty. Finally, a truly professional graphic equalizer in a smaller rack space package. When performance, value, and reliability are the most important considerations, the Ashly MQX Series offers the obvious solution to limited rack space equalization situations!
  • BrandAshly Audio
  • ModelMQX-2310
  • Part Number245-204
  • UPC844632051500
  • Product CategoryEqualizers
  • Weight11 lbs.
View similar products to the Ashly MQX-2310 Dual 31-Band EQ 2U
in the Equalizers product category.
Part # 245-204
