Ashly GQX-3102 Dual 31-Band EQ 3U
Brand:|Model: GQX-3102|Part # 245-207
Ashly has produced one of the most accepted and respected series of professional equalizers in the world.
Ships in 7-10 Business Days
List Price$775.00
You Save20%
Part # 245-207
  • Precision Wein-bridge filters for accurate response and low distortion
  • Constant "Q" design for low ripple and minimum interaction
  • High quality detented metal-shaft faders with center-off position
  • 10 position, 2-color LED level meter plus peak LED indicators
  • Selectable 15 dB or 6 dB range and switchable-tunable low cut filter
  • Balanced XLR, 1/4" TRS, and barrier strip audio connections
  • Internal power supply
Ashly has produced one of the most accepted and respected series of professional equalizers in the world. The GQX Series is available in three different configurations: the GQX-1502 features two channels of 15-band 2/3 octave equalization and a switchable high-pass filter. The GQX-3101 is a single-channel 31-band model, while the GQX-3102 features two channels of 1/3 octave EQ. Both the 1/3 octave models offer tunable high-pass filter circuits from 8 Hz to 200 Hz and 10-segment, two color LED meter displays, referencing 0 VU to +4 dBu.
Specifications: • Dimensions: 19" W x 5.25" H x 6" D.
The GQX models are designed to be significantly quiet without the need for noise reduction to be built into the equalizer circuit. Double-sided circuit boards with ground plane design are used in the filter sections for improved RFI and electrostatic immunity. Precision Wein-Bridge filters and carefully designed summing amplifiers combine to provide extremely accurate response, low noise, negligible distortion, and complete immunity to magnetic fields. All filters exhibit true constant "Q" response with no broadening near the "flat" setting. High slew-rate circuitry throughout the signal path results in clean, quiet, transparent sound. The faders used are a custom-manufactured metal-shaft type, with molded saddle knobs, for the ultimate in reliability and smooth "feel". Ashly's unique "T-Beam" front panel construction eliminates interconnections between the faders and the filters, resulting in a very rugged and rigid front panel.
Input and output connections include barrier strip terminals and 1/4" TRS phone jacks, as well as standard locking XLRs. Circuit ground may be lifted from chassis ground via the barrier strip. Ashly's servo-balanced output circuitry maintains unity gain even if pins 2 or 3 are connected directly to ground. Our transformer and power supply design result in lower hum noise and even greater line voltage range. In fact, these units still meet specifications when voltage drops down to as low as 93 VAC, making them the ideal choice when power stability presents a problem to the installer.
  • BrandAshly Audio
  • ModelGQX-3102
  • Part Number245-207
  • UPC844632051531
  • Product CategoryEqualizers
    (2 Reviews)
  • Weight15 lbs.
View similar products to the Ashly GQX-3102 Dual 31-Band EQ 3U
in the Equalizers product category.
