Ashly Dpx-200 Parametric Eq & Comp/limiter 1 Sp
Brand:|Part # 245-211
The use of proven circuitry from Ashly's popular MQX/PQX Series equalizers, combined with the CLX Series compressor/limiters, results in a powerful new tool that provides a simple solution to everyday audio applications.
Part # 245-211
  • Combines powerful EQ with smooth comp/limiting!
  • Separate Mic Pre and Line Inputs
  • 2 fully parametric bands plus high/low shelf filters
  • Compressor/Limiter uses peak detection circuitry
  • Balanced inputs and outputs
  • XLR and 1/4" TRS audio connections
  • Made in the USA
This item has been discontinued. For possible replacements or substitutions, please check the drop-down box below for a list of related items to view more products in this category. The use of proven circuitry from Ashly's popular MQX/PQX Series equalizers, combined with the CLX Series compressor/limiters, results in a powerful new tool that provides a simple solution to everyday audio applications. The DPX-200 EQ section consists of 4 bands of filtering; two full-bandwidth parametric EQs as well as a low-shelf and high-shelf filter. Two separate inputs are available in the DPX-200; a microphone preamp with input pad, and a line input. An input select switch and input level control are located on the front panel. The DPX-200 equalizer section and compressor/limiter may be used independently or chained together in series for even greater flexibility. Dimensions: 19" W x 1.75" H x 6" D.
  • BrandAshly Audio
  • Part Number245-211
  • UPC844632051579
  • Product CategoryEqualizers
  • Weight8 lbs.
View similar products to the Ashly Dpx-200 Parametric Eq & Comp/limiter 1 Sp
in the Equalizers product category.
