BUYOUT
309-001_ALT_0
309-001_ALT_1
309-001_ALT_2
309-001_ALT_3
309-001_ALT_4
Arvani by AuraSound 40" Powered Sound bar 2.1 System with Wireless Subwoofer and Remote
Brand:|Part # 309-001
The AuraSound Arvani 2.1 system, which includes a full-range sound bar and powerful wireless subwoofer, sounds better than systems costing twice as much or more. Loaded with features and input options, this stylish audio masterpiece makes movies, music, and games sound amazing. Enhance your home theater experience by adding the Arvani's exceptional clarity and deeper bass.
List Price$350.00
You Save43%
$199.00
Part # 309-001
  • Same audio performance as systems priced twice as high
  • Created by AuraSound, a leading manufacturer of high performance mini speaker drivers
  • Soundbar pairs effortlessly to subwoofer up to 60 feet away
  • Two digital inputs and two analog inputs for maximum connectivity
  • Convenient wireless remote controls volume, inputs, and audio settings
  • 20 watt per channel soundbar produces clean, articulate reproduction
  • 60 watt subwoofer punches out authoritative bass
Experience rich bass and crystal clear dialogue with this easy to set up AuraSound Arvani 2.1 soundbar and wireless subwoofer system. A wireless remote and all the cables you need are included. Just connect the powered soundbar to your audio source, pair it to the wireless subwoofer, and the system is ready to immerse you in a dynamic, engaging aural experience. Many audio input options are available; you can even pair it to an Arvani wireless iPod dock.
Compact, high fidelity, low distortion drivers made AuraSound famous, and the popular Aura Bass Shaker is recognized worldwide for its reliability and incredible low frequency output. The Arvani 2.1 system fits into small spaces, but will also fill larger rooms with its warm, realistic sound. Added features include SRS TVOL, which prevents commercials from being louder than the programs you are watching. Or turn on the SRS TSHD for an expansive audio image and deeper bass.
The black gloss finish gives the system a smooth, elegant look that fits well in any décor. At nearly 40", the 2-channel powered soundbar is equipped with two hand built 3" mid/bass woofers and one aluminum dome neodymium tweeter per channel. Packing six drivers into the design guarantees a full range of sound just from the sound bar. For extra low end depth, the wireless subwoofer takes charge. Backed by a 60 watt mono-block amplifier, the Arvani's 6-1/2" long throw subwoofer provides musical lows and thrilling home theater rumble that even the most distinguished ear can appreciate.
Special purchase buyout -- quantities are limited!
Sound Bar Specifications: • Four hand built 3" mid/bass woofers • Two neodymium magnet aluminum dome tweeters • 20 watts per channel @ 0.01% THD • Frequency response: 90 - 20,000 Hz • SPL: 100 dB • Inputs: One optical digital (S/PDIF), one digital coaxial (RCA), one stereo RCA, one stereo 3.5 mm • Dimensions: 39.83" W x 4.46" H x 4.24" D.
Subwoofer Specifications: • One 6-1/2" long throw (high excursion) subwoofer driver • 60 watt mono-block amplifier with 0.1% THD • Frequency response: 40 - 90 Hz • SPL: 95 dB • Wireless connectivity up to 60 feet • Dimensions: 9.84" W x 12.58" H x 12.25" D.
  • BrandAuraSound
  • Part Number309-001
  • UPC848864016573
  • Product CategorySound Bars / Speaker Bars
    (20 Reviews)
  • Weight35.0000 lbs.
View similar products to the Arvani by AuraSound 40" Powered Sound bar 2.1 System with Wireless Subwoofer and Remote
in the Sound Bars / Speaker Bars product category.
Arvani by AuraSound 40" Powered Sound bar 2.1 System with Wireless Subwoofer and Remote is rated 4.8 out of 5 by 20.
Rated 4 out of 5 by from Almost PerfectI have never used a sound bar before, so my frame of reference isn't great. I currently have 2 Snell EIII's (big, high quality floor standers) in my media room, along with a center channel--so this obviously is not going to compare well to that set-up. That said, the sound seems great for what it is, and set-up is quite easy.I'd give it 4 1/2 stars, but since that's not an option, I'll go with 4. Things that make it not perfect: Not being able to control sub power from the remote, and not being able to pair the unit to my Vizio or Comcast remote. Somehow, even in the days of universal remotes, I have way too many remotes... Otherwise, a great product and good value.
Date published: 2015-12-23
Rated 5 out of 5 by from Great sounding sound Bar.I bought this a few weeks ago to replace a Samsung unit I'd had for a year or so. I was looking for something that would sound better with music than the one I had. I must say I am truly impressed with this unit, the sound quality on both music and tv is far better than the Samsung, and better than any I've listened to. The bass is remarkably deep and clear for such a small unit- which leads me to my one complaint. The bass is sometimes too much for my taste and there is a limit on how low you can turn it down. Even at its lowest setting, it still can be a bit too much at times. I don't use the SRS settings because that boosts the bass even more. Even with that, I still rate this 5 stars because the overall sound quality is so much better than what I had. I also bought a blue tooth adapter that I plug into the sound bar that I use for music listening. Again, over all the sound is outstanding for such an inexpensive unit.
Date published: 2015-11-02
Rated 5 out of 5 by from Just what was reportedArrived in a short time. Plug and play...piece of cake...piece of cheesecake to get up and running.Took about 15 minutes to hang and start working out of the box.For two units the surround sound and base are superb.
Date published: 2015-10-26
Rated 5 out of 5 by from great featrures and great sound!I bought this AuraSound " soundbar and sub woofer last March. The sound in movies and music comes alive. I am very satisfied with this product. You should be also.
Date published: 2015-09-14
Rated 5 out of 5 by from Great deal as usual from Parts ExpressLooks much better in person hanging on the wall. I bought this for my 70" 4k Vizio that has horrible speakers. I could barely hear dialogue. This sound bar cleaned that up instantly.I gave this 5 stars because the price/performance is so good. There are 2 issues that I will explain.If you wall mount this and want to use an optical cable you need some sort of right angle cable that I'm not sure exists. The plugs on the back are far too shallow to wall mount with standard cables.The subwoofer didn't work! The subwoofer unit turned on but the sub had no output. It appeared that it paired with the sound bar because the sound bar LED would stop blinking but the sub didn't have output. I can't stand returning equipment so I turned off the sub, took the grill off the sub and found a green wireless card on the front. Unplugged it, plugged it back in. Turned the sub unit back on. The pairing seemed to work just based on the LED feedback on the bar/sub but still no output. The wireless card is plugged into another card that is connected by a ribbon cable to the inside electronics. I unplugged the ribbon cable and plugged it back in, turned on the sub and it worked.I'm guessing that during shipping it gets bounced around and the ribbon cable wasn't seated. Hope this helps someone else!
Date published: 2015-09-12
Rated 5 out of 5 by from Love it!I've had the sound bar two weeks and love it. Parts Express was a better deal than the big box stores and I got a great product. I knew it was going to sound good when I unpacked it and both the subwoofer and the sound bar were fairly heavy and not light. I'm happy with what I got!
Date published: 2015-04-15
  • 2016-02-09T06:23CST
  • co_hasreviews, tv_0, tr_20
  • loc_en_US, sid_309-001, PRD, sort_mostRecent
I lost the manual.  What are the pairing instructions for the wireless sub?
Asked by: Freddy123
What cord would I need to order for this in order to wall mount it below my tv? thanks
Asked by: bevin76
The unit uses a variety of inputs, it would depend on what cable you need for your TV. It has the following listed inputs: One optical digital (S/PDIF), one digital coaxial (RCA), one stereo RCA, one stereo 3.5 mm. Then you would need to confirm the length of the cable you need for your installation.
Answered by: GregT
Date published: 2016-02-04
What about the HDMI-video pass through? Do we need to use this at "audio-out" of the TV??
Asked by: Samuel111
It only has audio inputs: One optical digital (S/PDIF), one digital coaxial (RCA), one stereo RCA, one stereo 3.5 mm. You would need to connect it with one of those connectors from the "audio out" connections on your television.
Answered by: GregT
Date published: 2015-11-18
Is this soundbar system Bluetooth capable?
Asked by: diyLKR
This does not have Bluetooth built in but you could add a Bluetooth receiver to one of the analog inputs.
Date published: 2015-09-09
Hi there guys. I have the Arvani soundsystem and the bass, but i cant seem to find my remote. Is there any way possible to buy a remote. And i need it so bad! Please guys help me out.
Asked by: Murat
We don't offer remotes for this system separately but we may be able to scavenge one from a returned unit. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-08-31
Can this sound bar be mounted to the wall?
Asked by: JanL
Yes this can be mounted to the wall with the supplied brackets.
Date published: 2015-07-27
  • 2016-02-09T07:04CST
  • co_hasquestionsanswers, tq_22
  • loc_en_US, sid_309-001, PRD, sort_recentQuestionsFirst
Videos
