ART Tube MP Project Series Tube Mic Preamp with Limiter
Brand:|Model: TUBE MP PS|Part # 245-8602
The Tube MP Project Series is a professional quality audio interface that lets you connect microphone, instrument, and line level signals to a mixer or other audio input. This hybrid design is the latest in a long line of ART tube preamps.
Comparable Items In Stock:
Part # 245-8602
  • Hand selected 12AX7A tube
  • Up to 70 dB of clean, musical gain
  • High output signal drive capability
  • Fast FET limiter to prevent overload
  • Switch selectable input impedance
  • Precision LED metering
  • Built-in low noise phantom power supply
The Tube MP Project Series is a professional quality audio interface that lets you connect microphone, instrument, and line level signals to a mixer or other audio input. This hybrid design is the latest in a long line of ART tube preamps. We took our legendary Tube MP series and updated every aspect of the design, inside and out, while still maintaining a compact, reliable, and cost effective product. From the new all-aluminum stackable chassis to the precision LED level metering circuitry, we have improved virtually every aspect of our already successful Tube MP series. With up to 70 dB of clean musical gain and high output signal drive capability the cold digital world will melt with your mixes! Charge up your creativity with the Tube MP Project Series! The Tube MP is the world's most popular external tube mic preamp. Whether you're working with a computer, hard disk or digital multi-track recorder, the Tube MP's TEC award nominated design will allow you to obtain professional results at an affordable price. ART preamps offer warm tone, useful features, and are innovatively designed. Art's Tube MP add presence, clarity and fullness to any signal, and is exceptionally low-noise.
Specifications: • Frequency response: 10 Hz to 40 kHz, ±1 dB (typical) • Dynamic range: >100 dB (20 Hz to 20 kHz) • THD: <0.05% (typical) • CMRR: >60 dB (typical) • EIN: <-130 dB (XLR to XLR, A-weighted) • Maximum input level: +17 dBu (1/4"), +16 dBu (XLR) • Maximum output level: +20 dBu (1/4"), +26 dBu (XLR) • Input connections: 1/4" TRS unbalanced (1M Ohm), XLR female balanced • Output connection: 1/4" TRS unbalanced (600 Ohm), XLR male balanced, (<300 Ohm) • Maximum gain: 70 dB (XLR-XLR), +50 dB (1/4"-XLR) • Input gain pad: Switchable, 20 dB • XLR Input impedance: Switchable, 4.7k Ohms / 600 Ohms • Low cut filter: Switchable, -3 dB @ 40 Hz • Output phase: Switchable, normal/invert • Output limiter type: Switchable, fast & musical FET limiter, >20 dB limit range • Phantom power: Switchable, +48V DC, filtered, current limited • Signal metering: Precise LED array with a fast attack and moderate release • Tube type: 12AX7A hand selected • Chassis type: Aluminum anodized with integral/st.
  • BrandART
  • ModelTUBE MP PS
  • Part Number245-8602
  • UPC840402016489
  • Product CategoryMicrophone Preamps & Channel Strips
    (1 Reviews)
  • Weight2.7 lbs.
View similar products to the ART Tube MP Project Series Tube Mic Preamp with Limiter
in the Microphone Preamps & Channel Strips product category.
