ART SyncGen Time Code Generator
Brand:|Model: SyncGen|Part # 245-8600
The ART SyncGen is a simple to use and inexpensive way to improve the performance of your digital recording equipment while eliminating seemingly random pops and clicks that result from synchronization timing errors in recording systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$129.00
You Save23%
$99.00
Part # 245-8600
  • Stable and accurate time-base reference
  • 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176 kHz, 192 kHz sample rates
  • Four high-current 5 volt BNC word-clock outputs
  • Two "Zero Bit Digital Black" S/PDIF outputs on coaxial RCA connectors
  • LED indicators monitor termination and operating status of BNC outputs
  • Large, easy to read digital sample rate readout
  • Easy sample rate selection with memory recall after power down cycle
The ART SyncGen is a simple to use and inexpensive way to improve the performance of your digital recording equipment while eliminating seemingly random pops and clicks that result from synchronization timing errors in recording systems. A word-clock generator will centralize all of the timing of various pieces of digital equipment, reducing accumulated timing errors between the individual units that make up a digital recording chain. Designed for maximum versatility, the ART SyncGen will provide stable, sample accurate time based reference and can connect to digital audio equipment with either BNC word-clock or coaxial S/PDIF inputs. The ART SyncGen also acts as a system tester by confirming status of BNC word-clock cables and terminations and can verify which pieces of gear are internally terminated. The ART SyncGen will also test proper cable connections to ensure total system accuracy.
Specifications: • BNC word-clock outputs: = 5 Vpp into 75 Ohms, = 5.75 Vpp unterminated, 40 Ma Rms maximum output • S/Pdif Outputs: = 0.5 Vpp into 75 Ohms, = 1 Vpp unterminated, all audio bits set to zero "Digital Black" • Available sample rates: 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176 kHz, 192 kHz • Timebase accuracy: ± 10 Ppm @ 0ºC to 50ºC • Jitter: = 100 Psec RMS • External power supply: 8.5 – 14 Vdc or 7 – 12 Vac @ 500 Ma • Dimensions: 1.87" H x 4.61" W x 4.27" D • Dimensions: 47.5" H x 117" W x 108" D.
  • BrandART
  • ModelSyncGen
  • Part Number245-8600
  • UPC840402018247
  • Product CategorySystem Processors, Matrix, Routing
  • Weight1.89 lbs.
View similar products to the ART SyncGen Time Code Generator
in the System Processors, Matrix, Routing product category.
Part # 245-8600
