ART Phantom I 48V Power Supply
Brand:|Model: Phantom I|Part # 245-8674
The Phantom I is a great choice when matching phantom voltage to your mic. Mics perform best when driven by its rated voltage, no less. So for a 48V mic you would obtain best results with 48 volts of phantom power.
Comparable Items In Stock:
Part # 245-8674
Different condenser microphones specify different amounts of required phantom power. As a rule these ratings can range from 48 volts all the way down to 9 volts. Fortunately, there is some flexibility in terms of matching phantom voltage to your mic. A rough rule of thumb would be more is better. For example, a 24-volt condenser mic will run perfectly on 48 volts. In fact, mics rated at as little as 9 volts can often operate on 48 volts, but you should check with the manufacturer first. Conversely, a mic will generally perform best driven by not less than its rated voltage so, for a 48V mic, you would obtain best results with 48 volts of phantom power. The Phantom I is a great choice for the above needs.
Specifications: • Input connector: XLR female • Output connector: XLR male • Frequency response: 10 Hz-25 kHz • Output phantom power: 48V DC (± 2V) • Output noise: -115 dBV • Current drain: 14 mA • Power: 18V DC (adapter included) • Dimensions: 5.25" x 2.75" x 1.75" (130 x 74 x 45 mm).
ARTcessories™ are taking the audio world by storm and quickly becoming a popular brand with musicians, DJs and studio engineers everywhere around the World. Split, combine, mix, power... you name it. On stage, in the studio, in your living room, they’re easy to use and are built to last. For those times when you need a little box to fix a big need or to make more out of a smaller project, ARTcessories™ has you covered. You'll discover a robust line of useful tools which include a complete range of direct boxes, headphone amps, small mixers, mic cable combiner/splitters and much more. ARTcessories™ are designed to deliver affordable solutions for a multitude of audio needs for any size project.
  • BrandART
  • ModelPhantom I
  • Part Number245-8674
  • UPC840402014218
  • Product CategoryPhantom Power Supplies & Power Modules
  • Weight1.9 lbs.
View similar products to the ART Phantom I 48V Power Supply
in the Phantom Power Supplies & Power Modules product category.
Part # 245-8674
