ART PB 4x4 PRO Power Distribution System
Brand:|Model: PB|Part # 245-8638
Built on the foundation of the 4x4 PRO power distribution system are durably constructed, reliable power conditioners for use in many applications. Wherever power management systems are required, the 4x4 PRO will provide the surge protection you need to keep your rack safe from unwanted disruption.
List Price$139.00
You Save39%
$85.00
Part # 245-8638
  • APF - advanced power filtering
  • Power capacity of 1800 watts
  • Surge & spike protection
  • EMI & RFI filtering
  • 8 rear outlets with power adapter friendly positioning
  • One front-mounted unswitched power outlet
  • Rear mounted gooseneck light source
Frequently Bought Together
Presenting the 4x4 PRO Power Distribution System from ART. Built on the foundation of the popular 4x4 PRO systems are durably constructed, reliable power conditioners for use in many applications. Wherever power management system is required, the 4x4 PRO provides the surge protection you need to keep your rack safe from unwanted disruption. The 4x4 PRO system has an additional internal discrete module called APF™ (Advanced Power Filtering) which filters out digital and dimmer hash as well as any high frequency noise that is above the audio range. Some off-the-shelf add-on modules saturate and lose their filtering effectiveness as the load increases, but by using a high power discrete design we were able to create a filter that stays effective over the full operating range. By using both Common Mode and Differential Mode topologies in series for the filter design we are able to block virtually all of the unwanted noise that is between the AC line and ground, and also the two sides of the AC line. This has the additional benefit of reducing ground loop problems in your system. High frequency noise currents in particular are highly attenuated in both directions so that any line noise that could be generated by one of your components is not allowed to get back into your main A.C. wiring so if you use a number of PRO SERIES Power Conditioners in your setup, you can distribute and isolate the noisy components from the sensitive components in your system.
The PRO 4x4 power conditioner is designed with a power capacity of 1800 watts, surge/spike protection, APF with EMI & RFI filtering, front-mounted unswitched power outlet and an adjustable rear-mounted gooseneck light source for bright illumination behind the rack. The spacing and alignment of the rear outlets to accommodate various size power plugs and AC adapters.
Power Distribution System Overview
ART power distribution systems feature a 4x4 distribution on the back of the unit - four of the eight rear outputs are 1.25" apart. This allows the user to plug in wide power cables and multiple wall wart devices, and still have eight total power outlets to choose from.
Also features a surge and spike protection system, designed to protect powered equipment from harmful electric surges and spikes. The units also have RFI and EMI filtering, a 15 amp breaker, and a total power capacity of 1800 watts. The rugged, all-steel chassis occupies 1U-rack space, and are intended for installation into standard 19" equipment racks. 5ft power cord.
Specifications: • Power capacity: 1800 Watts • Circuit breaker: 15 Amp • Power outlets: Eight rear outlets • Power switch: Front location - On/Off • Power switch illumination: Yes - In On position • Circuit breaker: Front location • Filtering: EMI, RFI, Common mode passive • Differential mode in series • Protection circuit: Surge & spike protection • Construction: All-steel chassis • Light pipes: (SP, PS only) 2 Front pull-out, Shock mounted • Metering: (SP, PS only) input voltage • Metering: (PS only) current voltage.
  • Number of Outlets8
  • Special FeaturesRack Mountable
  • Cord Length5 ft.
  • ColorBlack
  • BrandART
  • ModelPB
  • Part Number245-8638
  • UPC840402017646
  • Product CategoryRack Mount Power Distribution
  • Weight6.3 lbs.
View similar products to the ART PB 4x4 PRO Power Distribution System
in the Rack Mount Power Distribution product category.
