ART MX622 Six Channel Stereo Mixer with EQ and Effects Loop
Brand:|Model: MX622|Part # 245-8646
The MX622 is a versatile mixer combining three balanced microphone or line level inputs with three stereo line inputs into a single stereo line level mix. Each mono balanced XLR input includes fully variable Input gain, Mic/Line switch, Clip indicator, and selectable 15 Volt Phantom power.
- Order Soon - Only 3 Left In StockMore Due In August 30, 2016
List Price$189.00
You Save21%
$149.00
Part # 245-8646
  • Three balanced XLR inputs with separate Mic/Line switch, Level control and Clip Indicator
  • Three pairs of RCA stereo inputs with separate Level controls
  • Selectable 15 Volt Phantom power for each Mic channel
  • Balanced 1/4" TRS Main outputs with Master Level control
  • Versatile Bass and Treble equalization on Main outputs
  • Stereo Record Out RCA jacks
  • Effects Loop with Effects Level control and In/Out switch
The MX622 is a versatile mixer combining three balanced microphone or line level inputs with three stereo line inputs into a single stereo line level mix. Each mono balanced XLR input includes fully variable Input gain, Mic/Line switch, Clip indicator, and selectable 15 Volt Phantom power. An external effects loop section provides a mono Send from the three Mic/Line channels to external equipment and stereo Returns with Effects Level and In/Out switch. Three stereo line level inputs are also provided via RCA type jacks with separate Level controls for each stereo pair. Stereo Record output RCA jacks provide full-level signal of the entire mix at all times. Main outputs are stereo balanced 1/4" TRS with Master Level and full range Bass/Treble equalization. The built in power supply and single high 19" rack mount format allows for easy installation and reliable operation.
  • Input Connections: XLR-F balanced (3), 1/4" unbalanced (2), RCA (6)
  • Output Connections: 1/4" TRS balanced (2), 1/4" unbalanced (1), RCA (2)
  • Input Impedance: 600/22K Ohms Mic/Line XLR inputs, 10K Ohms RCA inputs, 22K Ohms 1/4" EFX Returns
  • Output Impedance: 50 Ohms 1/4" Main outputs, 1K Ohms RCA Record outputs, 100 Ohms F/X output
  • Maximum Input Level: -10 dBu/+20 dBu Mic/Line XLR inputs, +20 dBu RCA line inputs, +20 dBu F/X inputs
  • Maximum Output Level: +24 dBu balanced Main outputs, +20 dBu RCA Record outputs, +20 dBu F/X output
  • Phantom Power: +15 Volts DC, regulated low noise
  • Maximum Gain: 56 dB/26 dB Mic/Line, 26 dB RCA inputs
  • Signal to Noise Ratio: >90 dB typical
  • THD: 0.01% Typical
  • Equalizer Range: ±12 dB @ 100 Hz & 10 kHz
  • Power Requirements: USA – 105~125 VAC / 50~60Hz, 15 Watts typical
  • Dimensions: 1.75" H x 19" W x 6" D (44.5 x 483 x 152 mm)
  • Weight: 6.2 lbs. (2.8 kg)
Audio Utilities by Applied Research and Technology are audio devices that have been designed and engineered to exceed high standards for audio performance and functionality. These innovative, high-quality components are perfect for virtually any audio application where precision frequency tailoring, reliable performance and rugged design are of the utmost importance. ART Audio Utilities deliver extremely precise and powerful flexibility, with quality features and reliable design criteria necessary for top-level audio performance.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs< 6
  • BrandART
  • ModelMX622
  • Part Number245-8646
  • UPC840402018995
  • Product CategoryLine Mixers
    (4 Reviews)
  • Weight5.6 lbs.
View similar products to the ART MX622 Six Channel Stereo Mixer with EQ and Effects Loop
in the Line Mixers product category.
