261-486_ALT_0
Arlington TVB613 TV Box Recessed Dual 110 and Dual Low Voltage Plate White
Brand:| Model: TVB613
The TV Box™ combines a recessed dual 110 duplex box with two low voltage brackets for mounting LCD and plasma TVs flush against your wall. Power plugs no longer inhibit a custom installation seen in commercials.
  • Helps to maintain a flush against the wall TV appearance
  • Fits between 16" studs
  • Paintable non-metallic finish
  • Two 110 duplex outlets with two low voltage brackets
261-486
Weight: 1 lbs.
IN STOCK
List Price$26.99
You Save26%
$19.98
Buy 10-up$17.78
Part # 261-486
The TV Box™ combines a recessed dual 110 duplex box with two low voltage brackets for mounting LCD and plasma TVs flush against your wall. Power plugs no longer stick out and inhibit that custom installation that you've seen in commercials. Use the low voltage section for mounting cable connector bulkheads, speaker binding posts, or other datacomm bulkheads. TV Box is 13" wide for mounting between studs, and features non-metallic material with a textured paintable finish. 110 outlet and low voltage devices sold separately.
  • BrandArlington Industries
  • ModelTVB613
  • Part Number261-486
  • UPC018997096302
  • Product CategoryLow Voltage Boxes & Mounting Brackets
    (7 Reviews)
  • Weight1 lbs.
View similar products to the Arlington TVB613 TV Box Recessed Dual 110 and Dual Low Voltage Plate White
in the Low Voltage Boxes & Mounting Brackets product category.
Arlington TVB613 TV Box Recessed Dual 110 and Dual Low Voltage Plate White is rated 4.4286 out of 5 by 7.
Rated 5 out of 5 by from Offers a clean neat installI installed vertically behind a 42" TV. Used one of the two slots for power and put a blank in the other slot. Used the other two trim plates for hdmi and audio. Now my TV has two HDMI, audio and power. The box trim is paintable. Excellent choice!
Date published: 2012-02-12
Rated 5 out of 5 by from Excellent SolutionPerfect solution for ensuring low profile mounting of flat panel TVs. Can be mounted horizontally or vertically. Will work retrofit or new construction. For retrofit opening must be cut flush to a stud.
Date published: 2010-03-18
Rated 4 out of 5 by from Good productThis expanded low voltage junction box did the trick and made my customers, "Happy Campers."Thanks AI.
Date published: 2009-08-05
Rated 4 out of 5 by from The best out thereGreat box, I am using to mount behind the wall mounting of a LCD tv. 2 large(high voltage) comparments, but also comes with splitter to make it 1 high voltage, 3 low voltage (for tv audio/video cables). It only comes with 1 wire holder for the large high voltage area and there is a hole for a second opening if you want it. The only bad thing is there isn't any easy way to hold/strain relief the av cables, so just tie them up on the wood stud if you need to.
Date published: 2009-04-13
Rated 5 out of 5 by from Every low profile instal needs thisYou can mount the box horizontal or vertical. Great quality plastic. Space for two 110 volt outlets.
Date published: 2009-03-04
Rated 4 out of 5 by from Clean InstallationExcellent way to mount flat screens very close to wall, allows for wires to protrude in cavity and keeps connectors from bending too tight. Fits nicely between studs and installs easily in remodel situations. Can be removed from wall to fish wires up wall with ease.
Date published: 2009-02-25
  • 2015-03-03T06:59CST
  • co_hasreviews, tv_0, tr_7
  • loc_en_US, sid_261-486, PRD, sort_mostRecent
how deep is the recessed portion?
Asked by: vtgoofy
From the outside front edge, the deepest section (for 110v outlets) is approximately 4" deep. The low voltage side is approximately 1-3/4" deep.
Answered by: RussR
Date published:
can this be mounted directly to the stud?
Asked by: vtgoofy
Yes, this unit can be mounted to a stud. It is suitable for new or existing construction, and can be mounted in a vertical or horizontal orientation.
Answered by: RussR
Date published: 2011-03-22
  • 2015-03-03T08:26CST
  • loc_en_US, sid_261-486, PRD, sort_recentQuestionsFirst
Customer projects that include: Arlington TVB613 TV Box Recessed Dual 110 and Dual Low Voltage Plate White
