Dual Gang Low Voltage Mounting Bracket
Arlington LV2 Dual Gang Low Voltage Mounting Bracket
Brand:| Model: LV2
This low voltage mounting bracket is designed for installations on existing construction (ie. retrofit applications). Non-conductive, smooth plastic material is perfect for communications, cable TV, computer wiring and audio installations.
  • Non-conductive material
  • Dog-ear mounting tabs
  • Open design serves as a template for cutouts
261-432
Weight: 0.1 lbs.
IN STOCK
$2.85
Buy 10-49 $2.02
Buy 50-up$1.64
Part # 261-432
This low voltage mounting bracket is designed for installations on existing construction (ie. retrofit applications). Non-conductive, smooth plastic material is perfect for communications, cable TV, computer wiring and audio installations. The open back design allows room for deep mounting depth of volume controls and can accommodate the speaker wire going to it for ease of installation. Additionally, this bracket serves as its own template for cut outs and adjusts to fit 1/4" to 1" thick wallboard paneling and drywall. Specially designed dog-ears flip out when the mounting screw is tightened for a secure fit against the wall.
  • BrandArlington Industries
  • ModelLV2
  • Part Number261-432
  • UPC018997109521
  • Product CategoryLow Voltage Boxes & Mounting Brackets
    (12 Reviews)
  • Weight0.1 lbs.
View similar products to the Arlington LV2 Dual Gang Low Voltage Mounting Bracket
in the Low Voltage Boxes & Mounting Brackets product category.
Arlington LV2 Dual Gang Low Voltage Mounting Bracket is rated 4.25 out of 5 by 12.
Rated 1 out of 5 by from Too smallDoes not fit Dayton Audio preconfigured wall plates purchased here at parts express and appears to be smaller than standard wall mount size. Discovered only after contractor installed 8 mounts throughout basement remodel. Cant understand why these are offered as a mounting option for wall plates sold by parts express....clearly not compatible.
Date published: 2013-09-03
Rated 2 out of 5 by from Too Small.I tried to use this Arlington 2-gang box/hanger with the Wired Home 2-gang 8-Port keystone wall plates available here on Parts Express. With all 8 boxes filled, the Arlington hanger was too narrow to accommodate the keystone jacks.I'll be returning these hangers.
Date published: 2013-02-07
Rated 5 out of 5 by from Best LV RingI have used several other old work low voltage brackets over the years, but these are the best. Install easily and they don't warp when tightened.
Date published: 2011-11-01
Rated 5 out of 5 by from Just rightJust what I needed for this project. Made the install look neat and at a reasonable price.
Date published: 2010-01-26
Rated 5 out of 5 by from Super easy retrofitI've purchased dozens of these for myself and friends to complete their system installs. Not only is it super easy to install, it protects the edge of the drywall when you're still pulling the cables.
Date published: 2009-12-16
Rated 5 out of 5 by from Mounting bracketJust installed this last night. I'm very happy with it. The bulk wall plate I used with it is securely mounted to the wall now. You just have to figure out the dimensions for the hole to cut.
Date published: 2008-10-08
  • 2015-02-25T06:58CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_261-432, PRD, sort_mostRecent
Customer projects that include: Arlington LV2 Dual Gang Low Voltage Mounting Bracket
