Single Gang Low Voltage Mounting Bracket
Arlington LV1 Single Gang Low Voltage Mounting Bracket
Brand:| Model: LV1
This low voltage mounting bracket is designed for installations on existing construction (ie. retrofit applications). Non-conductive, smooth plastic material is perfect for communications, cable TV, computer wiring and audio installations.
  • Non-conductive material
  • Dog-ear mounting tabs
  • Open design serves as a template for cutouts
  • Single gang size
261-431
Weight: 0.05 lbs.
IN STOCK
List Price$2.89
You Save28%
$2.08
Buy 10-49 $1.56
Buy 50-up$1.31
Part # 261-431
This low voltage mounting bracket is designed for installations on existing construction (ie. retrofit applications). Non-conductive, smooth plastic material is perfect for communications, cable TV, computer wiring and audio installations. The open back design allows room for deep mounting depth of volume controls and can accommodate the speaker wire going to it for ease of installation. Additionally, this bracket serves as its own template for cut outs and adjusts to fit 1/4" to 1" thick wallboard paneling and drywall. Specially designed dog-ears flip out when the mounting screw is tightened for a secure fit against the wall.
  • BrandArlington Industries
  • ModelLV1
  • Part Number261-431
  • UPC018997581754
  • Product CategoryLow Voltage Boxes & Mounting Brackets
    (18 Reviews)
  • Weight0.05 lbs.
View similar products to the Arlington LV1 Single Gang Low Voltage Mounting Bracket
in the Low Voltage Boxes & Mounting Brackets product category.
Arlington LV1 Single Gang Low Voltage Mounting Bracket is rated 4.6667 out of 5 by 18.
Rated 4 out of 5 by from Good product.A must buy. Really simplifies the install. Will buy again.
Date published: 2013-01-29
Rated 5 out of 5 by from Easy to install, nice and stableInstallation was easy and finished product resulted in a very tight, stable mounting. Works great.
Date published: 2012-10-17
Rated 5 out of 5 by from Awesome product for clean lookAwesome used in conjunction with a single gang bulk cable wall plate and produced a smooth appearance for my Plasma TV wall mounting used at the TV and at floor level on the wall to route my wire great product simplified my instillation greatly. The reason I gave it a 4.5 for features is because it was made of a flimsy plastic but hay it worked well and securely and smoothly fitted the wall plate. Would highly recommend these for this type of application.
Date published: 2010-12-27
Rated 5 out of 5 by from Excellent productWorks as advertised. No problems at all.
Date published: 2010-03-26
Rated 5 out of 5 by from Nothing else to say; get it.Works great.
Date published: 2010-02-19
Rated 4 out of 5 by from GreatGreat for prexisting installation
Date published: 2010-01-12
Customer projects that include: Arlington LV1 Single Gang Low Voltage Mounting Bracket
