Arlington Industries FSC3227R Hole-Saw Box Single Gang Electrical Box
Brand:|Model: FSC3227R|Part # 261-490
If you have a 3-1/4" hole saw, the Hole-Saw Box™ single gang electrical box will save you time and money. Installation is as easy as cutting a hole and turning two screws.
  • Uses a 3-1/4" hole saw for installation (hole saw sold separately)
  • 17 cubic inches of mounting volume
  • For devices and sconce fixtures up to 3 lbs.
Need to install a retrofit or old construction electrical box? If you have a 3-1/4" hole saw, the Hole-Saw Box™ single gang electrical box will save you time and money. Installation is as easy as cutting a hole and turning two screws. The Hole-Sax box features saw teeth that cut a path for device screws to hold firmly in place. The total mounting volume is 17 cu. in. and a maxi plate is required for receptacles. 3 lb. device and sconce fixture weight limit. NM cable connector included. Note: Hole saw sold separately.
  • BrandArlington Industries
  • ModelFSC3227R
  • Part Number261-490
  • UPC018997125255
  • Product CategoryLow Voltage Boxes & Mounting Brackets
  • Weight0.2 lbs.
View similar products to the Arlington Industries FSC3227R Hole-Saw Box Single Gang Electrical Box
in the Low Voltage Boxes & Mounting Brackets product category.
