Arduino TinkerKit Relay Module
Brand:|Model: T010010|Part # 320-372
This TinkerKit Relay module is an electrically operated switch that allows you to turn on or off a circuit using voltage and/or current much higher than the Arduino could handle.
  • Allows Arduino to control high-power circuits
  • Keeps Arduino discreet from circuit being controlled for maximum reliability
  • Requires Arduino TinkerKit Shield
The Arduino TinkerKit Relay Module works in conjunction with an Arduino board and the TinkerKit Shield to allow the Arduino to turn high-power circuits on or off, up to 250V 10A, keeping the Arduino totally electrically separate from the circuit being controlled. It can be configured as normally open or normally closed.
Specifications: • Dimensions: 1.94" x 0.94".
Note: As Arduino requires learning the Arduino programming language and some degree of electronic knowledge, Parts Express recommends it for experienced and dedicated hobbyists. We suggest thoroughly reading the materials available on the Arduino homepage before proceeding.
Arduino homepage:
Official Arduino forum:
  • BrandArduino
  • ModelT010010
  • Part Number320-372
  • UPC7640152110856
  • Product CategoryMicrocontroller Experimenter Boards
  • Weight0.05 lbs.
View similar products to the Arduino TinkerKit Relay Module
in the Microcontroller Experimenter Boards product category.
Part # 320-372
