BUYOUT
259-140_ALT_0
Arctic KEST-471BW 110 VAC Cooling Fan 120mm x 38mm 2-Wire Ball Bearing Aluminum Housing 100 CFM
Brand:|Model: KEST-471BW|Part # 259-140
The Arctic KEST-471BW is a high output 100 CFM 120 mm AC fan used in larger electronic equipment and rack cooling. It features a 7-blade plastic impeller, aluminum alloy frame, and 11" wire leads.
List Price$59.99
You Save67%
$19.50
Buy 4-9 $17.75
Buy 10+$13.97
Part # 259-140
  • Standard 120 x 120 x 38 mm frame size
  • 7-blade plastic impeller
  • Rugged aluminum alloy frame
  • Ball bearing
  • 11" wire leads with solder-tipped ends
  • Impedance protected
Popular-sized, high output 100 CFM AC fan that's used in larger electronic equipment and rack cooling. The Arctic KEST-471BW 120 mm fan features a 7-blade plastic impeller, aluminum alloy frame, and 11" wire leads. Factory buyout—limited quantities!
Specifications: • Voltage: 100/120 VAC • Frequency: 50/60 Hz • Current: 0.34/0.31 A • Power: 27.6/26.7 W • Speed: 2550/2750 RPM • Air flow: 105/100 CFM • Noise: 47/46 dBA • Bearing system: Ball bearing • Impeller: 7-blade plastic • Frame: Aluminum, painted black • Dimensions: 4-5/8" H x 4-5/8" W x 1-1/2" D (120 x 120 x 38 mm) • Mounting holes: 4-1/8" (105 mm) O.C. • Termination: Wire leads, 18 AWG, VW-1, Black, CSA-UR, soldered tipped ends, 11" long • Safety approvals: CE, TUV approved; UL recognized • Model: KEST-471BW.
  • Operating Voltage110~120 VAC
  • Size120 mm
  • Bearing TypeBall Bearing
  • BrandKEST
  • ModelKEST-471BW
  • Part Number259-140
  • UPC848864013794
  • Product CategoryEquipment Cooling
  • Weight1.1500 lbs.
View similar products to the Arctic KEST-471BW 110 VAC Cooling Fan 120mm x 38mm 2-Wire Ball Bearing Aluminum Housing 100 CFM
in the Equipment Cooling product category.
Is this new or used?
Asked by: potental customer
These products are new.
Date published: 2015-01-05
how to connect the two wired leads of the fan to 120 AC. Need special plugs ? I want to build a unit for my home theater amps and they need ventilation and cooling.
Asked by: Kostas
You will have to splice a lamp cord or any Edison style plug to the end of the leads in order to plug it into 120VAC.
Date published: 2014-01-20
  • 2016-02-12T07:12CST
  • loc_en_US, sid_259-140, PRD, sort_recentQuestionsFirst
