244-4000_ALT_0
244-4000_ALT_1
244-4000_ALT_2
244-4000_ALT_3
244-4000_ALT_4
244-4000_ALT_5
244-4000_ALT_6
244-4000_ALT_7
American DJ Vizi Spot LED Pro High Performance Moving Head Fixture
Brand:|Model: Vizi Spot LED Pro|Part # 244-4000
If you need a moving hard edge spot beam or a frost (wash) effect then the Vizi Spot LED by American DJ is the light for you.
  • 7 rotating interchangeable gobos + spot
  • SLOCK™ (Slide Lock) gobo changing system
  • 7 colors + UV filter + white
  • 4 operational modes: DMX, Master/Slave, Stand Alone & Sound Active
  • Pan/Tilt (8-Bit) + Fine Pan/Tilt (16-Bit)
  • 540° standard pan (optional 630°) and 270° tilt
The American DJ Vizi Spot LED Pro is a high performance fixture that can be used as a wash or spot. Featuring 7 rotating, interchangeable gobos and 7 colors each on its own independent wheel that can be used with the 3-facet or infinite prism wheel, this is a great asset to any light show. The 4 operational modes of DMX, Master/Slave, Stand Alone, and Sound Active give the operator endless options. Additional features include an easy to use LED DMX 4-Button menu system, 0-100% dimming, 540° pan, 270° tilt, speed controlled strobe, and 13° beam angle.
Specifications: • Multi-voltage operation: 100~240V, 50/60 Hz • Power consumption: 130W max • Lamp: 50W white LED source, 6500°K (60,000 hour rated) • Dimensions: 12" x 10" x 16.75"  (303 x 253 x 422 mm) • Weight: 23 lbs. (10.4 kg).
  • BrandAmerican DJ
  • ModelVizi Spot LED Pro
  • Part Number244-4000
  • UPC640282001953
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight24 lbs.
View similar products to the American DJ Vizi Spot LED Pro High Performance Moving Head Fixture
in the Moving Yoke & Scanner Intelligent Lighting product category.
