244-4124_ALT_0
244-4124_ALT_1
244-4124_ALT_2
244-4124_ALT_3
American DJ Micro Royal Galaxian Laser Effect Light with Royal Blue
Brand:| Model: Micro Royal Galaxian
The American DJ Micro Royal Galaxian laser is great when you want to take your party to the next level. This laser produces more than 200 blue and red beams that can be projected on a ceiling, wall, or dance floor for an energizing effect.
  • Projects more than 200 blue and red beams on a dance floor, ceiling or wall
  • Compact in size for easy transport
  • Includes 2 operational modes: Auto Mode or Sound Active Mode
244-4124
Weight: 2.35 lbs.
IN STOCK
Order Soon - Only 1 Left In StockMore Due In March 13, 2015
List Price$199.95
You Save25%
$149.99
Part # 244-4124
The Micro Royal Galaxian laser by American DJ is a must have for night clubs, bands, and mobile entertainers. The compact light weight housing design and the plug in and run built-in lighting programs in auto or sound active modes make it easy to use. Using the included RF wireless remote or push button feature on the back of the unit makes the change from auto mode to sound active mode easy. This laser gives you the ability to either hang it or sit it on virtually any flat surface using the double bracket design.
Specifications: • Red laser: 80 mW (650 nm) • Blue laser: 60 mW (450 nm) • Includes UL-listed multi-voltage power supply: 100-240 VAC, 50/60 Hz • Power consumption: 7W max • Dimensions: 6" x 4.75" x 2.5" (149 x 110 x 60 mm) • Weight: 2 lbs. (0.8 kg).
  • BrandAmerican DJ
  • ModelMicro Royal Galaxian
  • Part Number244-4124
  • UPC640282002790
  • Product CategoryLaser Lighting
  • Weight2.35 lbs.
View similar products to the American DJ Micro Royal Galaxian Laser Effect Light with Royal Blue
in the Laser Lighting product category.
American DJ Micro Royal Galaxian Laser Effect Light with Royal Blue is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from Good ValueI've had this for about a month and there were a few things that I liked, and a few things that I didn't like.The Pros:-A blue laser for $150 is a good deal-People like the effect-Surprisingly wide coverage angleThe Cons:-Unfortunately...The blue laser isn't bright. This needs to be used in very dark conditions to look good. Even when used with a blacklight, the blue is weak and boring.-There are far less red lasers than blue lasers.-When i received it, the internal rotating lens of the blue laser was unglued and barely hanging on. Not a huge deal, it was easy to remove the faceplate and glue it.-Sound active mode is LAME. The rotation speed and direction of the laser remains constant. The laser does not noticeably play to the beat of the music at all. It registers bass hits, and every few bass hits it will change colors WHILE staying the same speed and direction. The only way to make it change direction is to use the remote, and even then there is no way to vary the speed without switching out of sound active. On top of this, there is no strobe effect.So what do I think overall? I'd say get this and use it in conjunction with something else, perhaps the regular American DJ Micro galaxian. This way, there are more red lasers, and green is added to the mix. I will probably also add an American DJ LED QUEST as well so that at least one light is successfully going to the music. Not trying to bash on the laser but the sound active mode was a disappointment.
Date published: 2013-11-19
  • 2015-03-05T07:25CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_244-4124, PRD, sort_mostRecent
What type of battery does the remote use?
I purchased one of these and it did not have a battery for the remote. There are no markings for the voltage and type of battery on the remote, plus the manual has no mention of the type of battery to use.
Asked by: Jaybo
The battery this remote uses is model 23A which is a 12V alkaline.
Date published: 2013-10-29
  • 2015-03-05T09:46CST
  • loc_en_US, sid_244-4124, PRD, sort_recentQuestionsFirst
Customer projects that include: American DJ Micro Royal Galaxian Laser Effect Light with Royal Blue
