American Audio XSP-12A 300W 12" 2-Way Powered PA Speaker
Brand:|Model: XSP-12A|Part # 244-4330
The XSP-12A by American Audio is a two-way active loudspeaker encased in a light weight cabinet. This speaker has been designed to be used as both a portable and a permanently installed unit.
Part # 244-4330
  • Big sound in a small package
  • 1/4" and XLR mic/line inputs and line output
  • Durable construction
  • Sleek modern design
Frequently Bought Together
The XSP-12A's built-in power amplifier provides 300W of clean bi-amped power for plenty of output, and the unit has a time-aligned crossover to ensure the clearest possible sound for your program material. The 12" woofer is designed for high output, and the 1" high frequency driver is mounted to a 90° x 50° lens for clean and even dispersion. The XSP-12A features 1/4" and XLR microphone inputs, RCA and XLR line inputs, each with independent level control, and 1/4" and XLR line output to feed the signal to an additional powered speaker or subwoofer. Bass and treble controls are also included to tailor the overall sound to your specific taste or venue.
The cabinet includes a pole mount slot and rubber feet on the bottom of the unit for portable applications and also includes rigging points on the top, bottom, and rear of the unit for permanent and flight installations. All XSP Series speakers are 115/230VAC 50~60Hz compatible, with a selector switch on the back panel, and include convenient brackets which can be installed easily for floor monitor application.
The XSP Series PA speakers from American Audio demonstrate the company's continuing commitment to offer the highest quality and feature-rich products, all at an affordable price for professionals at all levels. Yes, you can sound like a million bucks without actually spending it!
Specifications: • Frequency response: 20 - 20,000 Hz • Dimensions: 23" H x 16" W x 12" D • Weight: 44 lbs. (20 kg).
  • Speaker TypeActive / Powered
  • Woofer Size12"
  • BrandAmerican Audio
  • ModelXSP-12A
  • Part Number244-4330
  • UPC640282000376
  • Weight43.6 lbs.
View similar products to the American Audio XSP-12A 300W 12" 2-Way Powered PA Speaker
