244-4318_ALT_0
American Audio VLP300 300W Power Amplifier
Brand:| Model: VLP300
The VLP300 is a 2-channel amp that's ideal for stage monitors, small venue PA systems and more. It will provide 150W RMS per channel of clean power to a 4 ohm load, 100W RMS per channel to 8 ohms, or 300W RMS to a bridged mono load (8 ohm minimum).
  • Versatile and reliable power amplifier
  • Level and clip LED indicators
  • Clean, simple front panel controls
  • Short circuit and thermal protection
244-4318
Weight: 28.2 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$279.95
You Save28%
$199.99
Part # 244-4318
The VLP Series power amplifiers from American Audio are serious gear for serious professionals, without the exorbitant price tag generally associated with other brands. The VLP300 includes an available high pass/low pass filter, selectable input sensitivity, and ground lift for maximum flexibility. Two cooling fans keep the unit running cool throughout your entire show. With 1/4" and XLR inputs, twist-lock and 5-way binding post outputs, the VLP300 is versatile enough to be useful in most any pro application, and built to last to provide you with many years of reliable service.
The VLP Series amplifiers from American Audio demonstrate the company's continuing commitment to offer the highest quality and feature-rich products, all at an affordable price for professionals at all levels. Yes, you can sound like a million bucks without actually spending it!
Specifications: • RMS output power: 150W/channel @ 4 ohms; 100W/channel @ 8 ohms; 300W bridge mono (8 ohm minimum) • Frequency response: 20 - 20,000 Hz (± 1 dB) • Damping factor: 260 (@ rated output power, 8 ohms) • Dimensions: 19" x 1.75" x 13.25" (1U rack mount) • Weight: 24 lbs. (11kg).
  • Power Output (RMS Per Channel @ 8 ohms)100 Watts
  • Output Channels2
  • Weight Range20 to 29 lbs.
  • BrandAmerican Audio
  • ModelVLP300
  • Part Number244-4318
  • UPC640282055574
  • Product CategoryAmplifiers - Live Sound
  • Weight28.2 lbs.
View similar products to the American Audio VLP300 300W Power Amplifier
in the Amplifiers - Live Sound product category.
Sound quality?
I am interested in this amp. I wonder about the sound quality as I want maximum fidelity.The best power amp I have here now is the Dayton APA 150 so I want equal or better quality.
Asked by: clod
This amplifier is more intended for pro applications, and only has 1/4 inch and XLR inputs. The signal level is much higher in pro sound applications than home audio as well.
Answered by: Chrisf
Date published: 2013-03-29
Can I use it and get quality sound in my home?
OK.If I order 1/4 phone plugs. Adapters .Mono. With RCA sockets on the ends for inputs. I have no problem with it capable of higher volumes.Do you see why I can't use it? I have a shop. 80 x 100 feet 20 ft to the top.
Asked by: clod
There are many people who use home gear and pro gear together. In many cases it is a good idea to use a signal converter like the ART cleanbox, #245-868 to provide a higher level balanced signal than a home preamp can provide.
Answered by: Chrisf
Date published: 2013-08-23
Customer projects that include: American Audio VLP300 300W Power Amplifier
