American Audio VLP2500 Power Amplifier 2 x 1100W at 4 Ohms
Brand:|Model: VLP2500|Part # 244-4324
The VLP2500 is a 2-channel amp that's ideal for stage monitors, PA systems, and more. It will provide 1100W RMS per channel of clean power to a 4 ohm load, 700W RMS per channel to 8 ohms, or 2200W RMS to a bridged mono load (8 ohm minimum).
  • Versatile and reliable power amplifier
  • Level and clip LED indicators
  • Clean, simple front panel controls
  • Short circuit and thermal protection
The VLP Series power amplifiers from American Audio are serious gear for serious professionals, without the exorbitant price tag generally associated with other brands. The VLP2500 includes an available high pass/low pass filter, selectable input sensitivity, built-in limiter, and ground lift for maximum flexibility. Two cooling fans keep the unit running cool throughout your entire show. With 1/4" and XLR inputs, and twist-lock and 5-way binding post outputs, the VLP2500 is versatile enough to be useful in most any pro application, and built to last to provide you with many years of reliable service.
The VLP Series amplifiers from American Audio demonstrate the company's continuing commitment to offer the highest quality and feature-rich products, all at an affordable price for professionals at all levels. Yes, you can sound like a million bucks without actually spending it!
Specifications: • RMS output power: 1100W/channel @ 4 ohms; 700W/channel @ 8 ohms; 2200W bridge mono (8 ohm minimum) • Frequency response: 20 - 20,000 Hz (± 1 dB) • Damping factor: 450 (@ rated output power, 8 ohms) • Dimensions: 19" x 3.5" x 17.75" (2U rack mount) • Weight: 50 lbs. (23kg).
  • Power Output (RMS Per Channel @ 8 ohms)700 Watts
  • Output Channels2
  • Weight Range50 to 59 lbs.
  • BrandAmerican Audio
  • ModelVLP2500
  • Part Number244-4324
  • UPC640282055734
  • Weight60 lbs.
View similar products to the American Audio VLP2500 Power Amplifier 2 x 1100W at 4 Ohms
