American Audio Sense 8 Compact 8" 2-Way PA Speaker
Brand:|Model: Sense 8|Part # 244-4336
The SENSE 8 features an 8" woofer designed to provide high output and smooth transition to the 1" compression driver. The HF driver is mated to a rotatable quadratic horn for silky highs and the dispersion to easily fill virtually any small to mid-size venue with superb sound and even coverage.
List Price$229.95
You Save26%
$169.99
Part # 244-4336
  • Great sound without the high price tag
  • Parallel twist-lock connectors
  • Rugged construction
  • Unobtrusive design and black finish
The SENSE Series PA speakers from American Audio are flexible enough to meet all your high-end requirements without breaking a sweat. The durable yet light weight plywood cabinets are constructed to provide years of service, and perfectly matched to the carefully chosen internal components. The asymmetric design facilitates duty as floor monitors, as well as reducing undesirable internal reflections and resonance.
The SENSE 8's aluminum frame woofer has a 50 mm voice coil, and the high frequency driver's lens is rotatable for 90° x 60° or 60° x 90° dispersion, giving you the flexibility you need to tackle virtually any situation with ease.
The SENSE Series features 8 ohm nominal impedance, parallel four pole twist-lock connectors, heavy-duty powder coated steel grills with acoustic foam lining, and integrated M8 rigging points in all corners. All this, plus ample power handling, smooth response, and rugged construction, adds up to a smart system that won't break your back, or the bank!
The SENSE Series by American Audio is a multi-functional, compact, and lightweight speaker system for flexible yet ambitious sound applications, and it won't cripple your budget. Yes, you can sound like a million bucks without actually spending it!
Specifications: • Power handling: 175W continuous, 350W program, 700W peak • Impedance: 8 ohms • Sensitivity: 121 dB peak • Frequency response: 88 - 20,000 Hz (-3 dB); 75 - 21,000 Hz (-10 dB) • Monitor angle: 45° • Dimensions: 17.165" H x 9.84" W x 9.05" D • Weight: 22 lbs. (10 kg).
  • Woofer Size8"
  • BrandAmerican Audio
  • ModelSense 8
  • Part Number244-4336
  • UPC819730017567
  • Weight25.5 lbs.
View similar products to the American Audio Sense 8 Compact 8" 2-Way PA Speaker
