Buyout Special
309-177_ALT_0
309-177_ALT_1
Allison AL10 10" 125W Powered Front Firing HT Subwoofer
Specifications: • 10" high-excursion woofer • 125 watt RMS amplifier • Frequency response: 25-180 Hz (-3 dB) • Dimensions: 19" H (20-3/4" H with spikes) x 14" W x 18" D.
  • Adjustable crossover 40 to 140 Hz
  • High output, bass-reflex design
  • Flared port for low port chuffing
  • Solid 3/4" MDF cabinet construction
  • Front-firing 10" subwoofer
309-177
Weight: 52.3 lbs.
Only the best possible components were considered for use in construction of this subwoofer, and each subwoofer has been designed to create amazing low frequency performance at a price that's more affordable than many "high-end" subwoofers. A flared port has been used to reduce port chuffing and sound localization for unlimited placement options. Stereo line-level inputs and parallel outputs allow these subwoofers to be used in a 2.1 setting or for stereo subwoofer applications, and a mono LFE input with a Crossover Bypass switch enables use with a receiver that low-passes information to a subwoofer. Lastly, a variable phase adjustment helps to adapt each subwoofer to unique rooms for the greatest amount of output. Specifications: • 10" high-excursion woofer • 125 watt RMS amplifier • Frequency response: 25-180 Hz (-3 dB) • Dimensions: 19" H (20-3/4" H with spikes) x 14" W x 18" D.
  • BrandAllison Acoustics
  • Part Number309-177
  • UPC844632082467
  • Product CategoryPowered Subwoofers
    (7 Reviews)
  • Weight52.3 lbs.
View similar products to the Allison AL10 10" 125W Powered Front Firing HT Subwoofer
in the Powered Subwoofers product category.
Customer projects that include: Allison AL10 10" 125W Powered Front Firing HT Subwoofer
