Allen & Heath ZED-24 16 Mic/Line 4 Stereo Input Mixer w/USB
Brand:|Model: ZED-24|Part # 246-2236
Allen & Heath's ZED-24 is a small format, USB-equipped stereo mixer for live and recording applications. The feature-set is incredibly advanced for a mixer at this level – it has 23 independent sources to the mix, 10 independent outputs, 4 aux sends, and more.
OUT OF STOCK
Due In: 2/19/2016
List Price$799.00
You Save13%
$699.00
Part # 246-2236
  • DuoPre mic preamplifier
  • Stereo imaging control on every channel
  • Professional 100mm faders
  • USB send and return for PC/MAC with controls for recording playback and effects
  • Advanced monitoring facilities
  • Stereo record out
  • Alternative stereo out
Allen & Heath's ZED-24 is a small format, USB-equipped stereo mixer for live and recording applications. The feature-set is incredibly advanced for a mixer at this level – it has 23 independent sources to the mix, 10 independent outputs, 4 aux sends, a USB send & return (for PC or Mac recording, playback and effects), a unique dual stereo input capability, and some very advanced monitoring facilities. In fact, ZED-24 is so packed full of great features that you'd think it would cost much, much more! The ZED-24 can be used for many different tasks, whether in live performance, utilizing plug-in effects via USB, live recording via USB and Cakewalk, studio recording or mixing down to produce your own 2-track recordings.
Inputs
One of the great things about the ZED series is the number and variety of things you can plug in. In addition to the sixteen mono channels there are four stereo channels, each with a main stereo input on jack sockets, and with the ability to take additional stereo inputs from phono sockets or from the USB audio input, flexibility gives you control. In all, ZED-24 boasts 129 different controls on its front panel - way more than any of the competition! 16 mic/line channels are provided on ZED-24 - plenty for mics or DI boxes for larger bands or demanding applications requiring more inputs than the ZED-14. 4 stereo line inputs, 3 with dual inputs. All inputs have independent gain control.
DuoPre™
Based on the proven pre-amps from the hugely successful PA series, the ZED series has new DuoPre™ pre-amps, which use a two stage design, with carefully controlled amounts of gain in each stage. When amplifying the signal from the XLR input, the gain range is huge - 69 dB of range to be exact - and is very evenly distributed around the gain control, meaning better control of signal level. Most of the gain comes from the first stage, so unwanted noise is kept to a minimum. Line level signals are simply plugged into the second stage of the pre-amp by using the line input jack socket, which has the great advantage of less noise when using the line input.
EQ section
ZED-24 features a responsive 3-band, swept mid frequency design with MusiQ - optimized slope (or Q factor) for equalizing individual instruments. HF and LF also boast Xtra Boost giving you extra control.
Auxiliary sends
4 aux sends are provided, of which 1 & 2 are pre-fade for foldback monitoring, and 3 & 4 post-fade for effects sends. A stereo signal can be sent from auxes via USB to computer to create 2 separate record feeds independent of the main LR mix (1&2) and or used as FX sends (3&4).
USB audio flexibility
Getting audio to and from a computer easily is now a common requirement for live sound and music production. The way we have implemented this on ZED is super-flexible and super-easy! No longer do you need to fiddle around the back of your PC to get to the soundcard inputs, only to find that the levels are all wrong and noisy. Just plug in a USB lead to your ZED, select the USB routing on the mixer and the device on your computer and that's it! Quality audio to and from your PC or Mac. Three switches provide different send/return configurations for recording, playback and utilizing external FX.
Build
At this level, most mixers are built using a single, flat PCB with all the pots and switches attached at right angles. ZED-24 utilizes individual vertically mounted channel circuit boards with each rotary control fixed with a metal nut to the front panel - making a much more robust product that will resist damage and give years of reliable use. ZED also has professional 100mm faders for ultimate control over your levels.
SONAR LE - provided Free!
We have teamed up with Cakewalk to bundle SONAR LE with this ZED mixer. The two team up together in many ways - for example straightforward recording of a stereo mix, recording tracks individually to build up a song, or for inserting a SONAR LE effects plug-in.
ALLEN&HEATH has forged a solid pedigree in the pro audio market and with 35 years experience under our belt it's safe to say we know our customers and their needs. We pride ourselves in creating products for everyone involved in musical performance whatever their experience or budget. Our small format mixers have been designed with the same commitment to professionalism and detail that has made ALLEN&HEATH a leading name associated with larger format consoles. Whether you are a PA rental company, touring or recording artist, bar, nightclub, house of worship, school or theater, ALLEN&HEATH's range of small live sound mixers have been designed with users in mind, providing all the features and functionality you need in one compact desk.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesUSB Connectivity
  • XLR Mic Inputs16 to 22
  • BrandAllen & Heath
  • ModelZED-24
  • Part Number246-2236
  • UPC6938122229297
  • Product CategoryMixers - Live Sound & Recording
  • Weight31.95 lbs.
View similar products to the Allen & Heath ZED-24 16 Mic/Line 4 Stereo Input Mixer w/USB
in the Mixers - Live Sound & Recording product category.
