Allen & Heath ZED-22FX 16 Mic/Line 3 Stereo Mixer w/USB & FX
Brand:|Model: ZED-22FX|Part # 246-2234
Allen and Heath's ZED-22FX small format mixer has custom FX and USB interface, for live and recording applications. 16 essential time-delay effects add to the already bulging feature set.
ORDER TODAY
Ships in 7-10 Business Days
List Price$899.00
You Save11%
$799.00
Part # 246-2234
  • 16 mono mic/line inputs
  • 16 internal time-delay effects
  • Stereo imaging control on every channel
  • 3-band EQ with swept mid
  • 4 auxiliary sends (2 pre, 2 post)
  • Global 48V phantom power
  • 3 dual stereo inputs with 2-band EQ
Allen and Heath's ZED-22FX small format mixer has custom FX and USB interface, for live and recording applications. Our DSP engineers have been working hard, crafting and refining beautiful reverb algorithms. The effects are available nowhere else - this quality and integration is only available from the ZED FX. 16 essential time-delay effects add to the already bulging feature set. The mixer is ideal for small groups who don't want to carry around an effects unit with their gear but who still want great quality FX at their gigs and on their recordings. In addition to the DuoPre™ mic pre-amps, 100 mm faders and MusiQ EQ section which are shared with the whole ZED range, the ZED FX has 16 unique effects, designed by our DSP team, here in Cornwall. ZED FX are easily controlled using 3 buttons and 9 LEDs. Quickly tap the ideal delay time or 'dial-in' the perfect amount of reverb on the lead vocal. One-stop navigation and editing... In fact, just as easy as your effects pedals. The USB audio interface, with its uniquely flexible capability, allows different signals to be sent to USB, from LR or from selected aux buses. The USB return signal can be routed straight to the LR mix or to a stereo channel. The connectors are placed on the top surface for easy plugging & patching, and the construction, with individual circuit boards firmly nutted to the top panel, is as rock solid as Allen & Heath's top of the range ML Series mixers.
MusiQ
ZED-22FX features a responsive 3-band, swept mid frequency EQ design which utilises MusiQ – with optimised slope (or Q factor) for equalising individual instruments.
DuoPre™
Based on the proven pre-amps from the hugely successful PA series, ZED-22FX has DuoPre pre-amps, which use a two stage design, with carefully controlled amounts of gain in each stage. When amplifying the signal from the XLR input, the gain range is huge - 69dB of range to be exact - and is very evenly distributed around the gain control, meaning better control of signal level. Most of the gain comes from the first stage, so unwanted noise is kept to a minimum. Line level signals are simply plugged into the second stage of the pre-amp by using the line input jack socket, which has the great advantage of less noise when using the line input and also matching to a higher input impedance.
ZED-FX
ZED-22FX has an essential selection of 16 time-delay effects, designed for small groups who don’t want to carry around an effects unit with their gear but who still want great quality FX at their gigs and on their recordings. Our DSP engineers worked hard, crafting and refining beautiful reverb algorithms to enhance every performance. These effects are available nowhere else at this price point – this quality and integration is only available from the ZED-FX. ZED effects are easily controlled using 3 buttons with 9 display LEDs. For example, the ideal delay time can be quickly tapped-in, or the perfect amount of reverb on the lead vocal can be dialled-in. There is one-stop navigation and editing – in fact, it’s just as easy as using effects pedals. To alter effects parameters, the TAP button is held down and the up/down buttons pressed to adjust the specific parameter for that effect, for example, the decay length on PLATE, or the depth on CHORUS.
SONAR X1 LE – Provided Free!
We’ve included Cakewalk SONAR X1 LE with ZED-22FX so you can immediately start to use it to create your own music – just add a PC and it couldn’t be easier to get going. You’ll be able to record from your ZED mixer, create tracks and arrange songs, then play back to ZED via the USB port. You can use SONAR X1 LE and your ZED mixer together in many ways – e.g. straightforward recording of a stereo mix, recording tracks individually to build up a song, or using the USB port and software as an effects loop.
ALLEN&HEATH has forged a solid pedigree in the pro audio market and with 35 years experience under our belt it's safe to say we know our customers and their needs. We pride ourselves in creating products for everyone involved in musical performance whatever their experience or budget. Our small format mixers have been designed with the same commitment to professionalism and detail that has made ALLEN&HEATH a leading name associated with larger format consoles. Whether you are a PA rental company, touring or recording artist, bar, nightclub, house of worship, school or theater, ALLEN&HEATH's range of small live sound mixers have been designed with users in mind, providing all the features and functionality you need in one compact desk.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesDigital Effects,USB Connectivity
  • XLR Mic Inputs16 to 23
  • BrandAllen & Heath
  • ModelZED-22FX
  • Part Number246-2234
  • UPC6938122230903
  • Product CategoryMixers - Live Sound & Recording
  • Weight33 lbs.
View similar products to the Allen & Heath ZED-22FX 16 Mic/Line 3 Stereo Mixer w/USB & FX
in the Mixers - Live Sound & Recording product category.
