Allen & Heath MixWizard WZ3:20S Mixer 4 Mono/8 Stereo/2 Out W320S
Brand:|Model: WZ3:20S|Part # 246-2180
Now upgraded to WZ3 status, the 20S remains a favorite mixer for small broadcast studios, internet radio stations , project studios and stereo sub-mixing anywhere.
  • Compact console designed for professional live sound and general purpose mixing
  • 4 mono mic/line channels
  • 8 full feature dual stereo input channels and 2 stereo return inputs
  • Channels feature a 4 band EQ (semi-parametric with high pass filter on the mic/line channels)
  • Channels feature 6 aux sends with combinations of pre/post switching and 100 mm faders
  • Console can be operated free standing or in a 19" rack or flightcase
Now upgraded to WZ3 status, the 20S remains a favorite mixer for small broadcast studios, internet radio stations , project studios and stereo sub-mixing anywhere. Featuring the new WZ3 preamp and responsive EQ, the WZ3 20S provides 12 channels with no fewer than 4 mono and 18 stereo sources. On the WZ320S, 8 dual stereo input channels are provided, each with TRS jack 'A' and XLR 'B' inputs. These may be mixed together into the channel or mode switched to provide up to 16 independent sources to the mix - ideal for multi-stereo keyboard and recording applications.
Specifications: • Maximum output level: XLR +26 dBu into 600 ohms max load; Jack +21 dBu into 2K ohm max load • Internal headroom: Channels +21 dB; Mix +23 dB • Meters: 3 colour LED, quasi peak response • Sensitivity: 0VU = +4 dBu at XLR output • Master meters: 12 segment -30 to +16 dB • Channel meters: 2 segment -12, +16 dB (5 dB before clip) • Frequency response: 20 Hz to 50 kHz +/-0.5 dB • THD+n at +10 dBu 1 kHz: Channel to mix out < 0.004% • Crosstalk at 1 kHz: Fader shutoff >90 dB, Channel mute >100 dB, Inter channel >90 dB • Noise (RMS 22 Hz-22 kHz): Mic EIN -128 dB, Residual output noise < -95 dBu (-99 dB S/N), LR unity fader mix noise < -83 dBu (-87 dB S/N) • Channel HPF: 12 dB/octave below 80 Hz • Mono EQ: HF Shelving, +/-15 dB, 12 kHz; HM Peak/dip, +/-15 dB, 500 Hz to 15 kHz, Q=1.8; LM Peak/dip, +/-15 dB, 35 Hz to 1 kHz, Q=1.8; LF Shelving, +/-15 dB, 80 Hz • Stereo EQ: HF Shelving, +/-15 dB, 12 kHz; HM Peak/dip, +/-15 dB, 2.5 kHz, Q=1.8; LM Peak/dip, +/-15 dB, 250 Hz, Q=1.8.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs< 6
  • BrandAllen & Heath
  • ModelWZ3:20S
  • Part Number246-2180
  • UPC6938122228306
  • Product CategoryMixers - Live Sound & Recording
  • Weight31 lbs.
View similar products to the Allen & Heath MixWizard WZ3:20S Mixer 4 Mono/8 Stereo/2 Out W320S
in the Mixers - Live Sound & Recording product category.
