242-5930_ALT_0
242-5930_ALT_1
AKG WMS 40 MINI2 Vocal Set Band 45A UHF Dual Handheld Wireless Microphone System 660.700 MHz
Brand:| Model: WMS 40 MINI2 VOC 45C
The WMS 40 MINI2 Vocal Set 45A by AKG is a dual wireless handheld microphone system that gives you the best possible, most realistic sound while having an unbeatable price-to-performance ratio.
  • Plug and play feature makes for easy setup in seconds
  • Cardioid polar pattern for trouble free use on narrow stages
  • 30 hours of operation from a single AA size battery saves you money in the long run
  • Switched mode power supply has a universal connector kit for worldwide use
  • UHF-band frequency 660.700 MHz
242-5930
Weight: 3.15 lbs.
IN STOCK
List Price$279.00
You Save29%
$199.00
Part # 242-5930
The AKG WMS40 MINI2 Dual Vocal Set is a true plug 'n' play wireless solution providing crystal clear audio sound for small stages, clubs, and places of worship. The two included handheld transmitters feature a dynamic cardioid capsule for maximum gain before feedback protected by a rugged wire mesh cap. Their extremely long battery life of 30 hours off a single AA battery saves money in day-to-day use. The receiver has an illuminated ON/OFF button that switches both channels simultaneously and offers two balanced outputs via 1/4" jack connectors. System includes: SR40 receiver, two HT40 handheld transmitters, universal power supply with US/UK/EU adapter, and two AA size batteries.
System specifications: • Operating Frequency: 660 to 865 MHz, fixed frequency • Audio bandwidth: 40 Hz to 20 kHz • Signal/noise ratio: typ. 105 dBA.
SR 40 MINI receiver specifications: • Audio outputs: bal. 1/4" jack, output level adjustable, at rated deviation: 500 mV rms • Power supply: 110~240 VAC • Dimensions: 5.2" x 1.7" x 5.2" (133 x 43 x 132 mm).
HT 40 MINI transmitter specifications: • RF output power: typ. 10 mW (ERP) • Dimensions: 9" x 2" (230 x Ø 52,5 mm).
  • Frequency BandUHF
  • BrandAKG Acoustics
  • ModelWMS 40 MINI2 VOC 45C
  • Part Number242-5930
  • UPC885038033103
  • Product CategoryHandheld Wireless Systems
    (4 Reviews)
  • Weight3.15 lbs.
View similar products to the AKG WMS 40 MINI2 Vocal Set Band 45A UHF Dual Handheld Wireless Microphone System 660.700 MHz
in the Handheld Wireless Systems product category.
AKG WMS 40 MINI2 Vocal Set Band 45A UHF Dual Handheld Wireless Microphone System 660.700 MHz is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from Good wireless systemNice pick up & good soundGood price-- and more////
Date published: 2013-10-10
Rated 5 out of 5 by from Parts Express A#1My recent wireless mic. purchase was a good one. VERY GOOD QUALITY & PERFORMANCE! ALSO AM VERY pleased with their tech support.
Date published: 2013-09-16
Rated 4 out of 5 by from Great for the moneyIf you need two mic make sure there are no TV stations in your aria on ch.s 45 to 47 or they will not work . You will have to spend more and assignable Chanel mic like the more expensive Shure models.
Date published: 2013-02-11
Rated 4 out of 5 by from Good for the PriceThis AKG Mini series is a good value for the price. The reception is as good as my old broadcast quality TOA. The sound quality is nearly as good too. The difference lies in the handling noise. I can toss the TOA in the air ,catch it with one hand ,and hear only a tine "tine" amount of handling noise. You will hear this AKG if you pass it from one hand to the other ,or from person to person. It should be in a shock mount if you put it on a podium. The handling noise is better then a Sure PG58 but not nearly as good as an SM58. I would not use it in a live band unless it was on a shock mount stand that was never touched. For general nonprofessional work I think it is the best $200.00 pair of mic you will find. Better then a PG58 and no wire. Noisy bar,cheep Karaoke fine. I have heard many "much worse" inexpensive wired & wireless. It's not a $3000.00 Sennheiser.
Date published: 2012-12-19
  • 2015-07-04T07:43CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_242-5930, PRD, sort_mostRecent
Customer projects that include: AKG WMS 40 MINI2 Vocal Set Band 45A UHF Dual Handheld Wireless Microphone System 660.700 MHz
