AKG WMS 40 MINI Instrumental Set Band 45A UHF Guitar Wireless System 660.700 MHz
Brand:|Model: WMS 40 MINI INST 45A|Part # 242-5920
The WMS 40 MINI Instrumental Set 45A by AKG is a wireless guitar and instrument system featuring the smallest and lightest bodypack transmitter in its class at an unbeatable price-to-performance ratio.
List Price$159.00
You Save38%
$99.00
Part # 242-5920
  • Plug and play feature makes for easy setup in seconds
  • Smallest and lightest bodypack transmitter in its class
  • 30 hours of operation from a single AA size battery saves you money in the long run
  • Switched mode power supply has a universal connector kit for worldwide use
  • UHF-band frequency 660.700 MHz
The AKG WMS40 MINI Instrument Set is a true plug 'n' play wireless solution providing crystal clear audio sound for small stages, clubs, and places of worship. The included bodypack transmitter provides a professional mini XLR connector, compatible with guitar and bass levels, headsets, and instrumental mics. Its extremely long battery life of 30 hours off a single AA battery saves money in day-to-day use. The receiver comes in an ultra compact housing and offers a 1/4" jack output. System includes: SR40 receiver, PT40 mini bodypack transmitter, MKG L instrument cable, universal power supply with US/UK/EU adapter, and AA size battery.
System specifications: • Operating Frequency: 660 to 865 MHz, fixed frequency • Audio bandwidth: 40 Hz to 20 kHz • Signal/noise ratio: typ. 110 dBA.
SR 40 MINI receiver specifications: • Audio outputs: bal. 1/4" jack, output level adjustable, at rated deviation: 500 mV rms • Power supply: 110~240 VAC • Dimensions: 5.2" x 1.7" x 5.2" (133 x 43 x 132 mm).
PT 40 MINI transmitter specifications: • RF output power: typ. 10 mW (ERP) • Dimensions: 2.4" x 3" x 1.2" (60 x 75.5 x 30 mm).
  • Frequency BandUHF
  • BrandAKG Acoustics
  • ModelWMS 40 MINI INST 45A
  • Part Number242-5920
  • UPC885038031697
  • Product CategoryGuitar & Instrument Wireless Systems
    (4 Reviews)
  • Weight2.3 lbs.
View similar products to the AKG WMS 40 MINI Instrumental Set Band 45A UHF Guitar Wireless System 660.700 MHz
in the Guitar & Instrument Wireless Systems product category.
AKG WMS 40 MINI Instrumental Set Band 45A UHF Guitar Wireless System 660.700 MHz is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from Good sound quality at a great priceI've played bass for over 40 years, play expensive basses and have used many supplied wireless systems for different events however, this is the first wireless unit I have owned personally. I bought it about 2 months ago but was concerned the unit would effect my bass tone. So I spent time (as per the instructions) ensuring that the aggressive tone of my active basses did not continually light the clip light on the base unit by adjusting the signal level from the belt pack. Bingo. A great clear, undistorted sound even from the B string of my 5 and 6 string basses.I have successfully used the unit on several gigs already and am amazed how good it is for the price. My only concern may be the lightness of the plastic belt pack. Just have to protect it well. Great product.
Date published: 2015-04-03
Rated 3 out of 5 by from Get what you pay forSound good on guitar. However, this is not a "diversity" system; it will occasionally make crackling and static when moving around. Considering the price, this is acceptable.
Date published: 2014-12-07
Rated 5 out of 5 by from Great wirelessI've owned this unit for about a year and it works great. I thought I would try it out and was worried that it might negatively affect my guitars tone. Happy to say that it did not! Combine this with Parts Express great service and this is a total winner.
Date published: 2014-10-27
Rated 5 out of 5 by from Easy peasyI bought this system based on online reviews and was thrilled with how true they were. I play the violin and used it in a hall with 300 people in it and the sound was consistent and full. It was a piece of cake to use, I didn't read any instructions and had it up and running within minutes of taking it out of the box. This means a lot coming from a noob like me. I highly recommend this system. Just take good care of it, the price is low because it is made of plastic so be sure not to drop it!
Date published: 2012-09-26
  • 2016-04-30T06:27CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_242-5920, PRD, sort_mostRecent
I have 4 instruments that would all need transmitters, transmitting on the same channel....I only need one receiver. Can I purchase 3 additional transmitters? How much will each cost?  Thanks Jeff
Asked by: MoonDogSolo
Date published: 2015-10-02
Can you use two of these devices together....for instance bass player uses one device while guitar player uses another
Asked by: jojo26
Yes as long as you order two different frequencies.
Date published: 2014-12-31
  • 2016-04-30T06:47CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • loc_en_US, sid_242-5920, PRD, sort_recentQuestionsFirst
